AEM Sync issue / cutting out?
Old Nov 11, 2010 | 03:29 AM
h22aholset's Avatar
Default AEM Sync issue / cutting out?
Hi All,
Ive got h22a fully built running holset hx40. I have an aem ems series 1 and aem cdi module.
Car drives fine. The only issue i have is that it never starts first time, on second turn it fires up straight away. Then unless i hold the revs high it wants to cut out. Once driving if im coming to a stop and dump the clutch in the revs drop it cuts out.
From what i have read, its leading me to believe its a common problem and that when the revs drop it looses sync signal and cuts out.
Is there a solution to this? Ive been told upgrading to AEM EMS Series 2 will fix the issue. Its idle is set to 1000rpm at the mo, i was thinking about increasing this to try and see if that works.
Old Nov 16, 2010 | 08:47 AM
Rtype16's Avatar
Default Re: AEM Sync issue / cutting out?
This is a tuning issue and not a sync issue.
gaskleppie
Engine Management and Tuning
Feb 6, 2017 07:50 AM
daigo
Apr 26, 2015 09:11 PM
thegatekeeper14
Jul 4, 2013 01:16 PM
hello1320
Feb 10, 2010 03:14 PM
