Vtec Solenoid Valve Service
Old Nov 10, 2010 | 10:21 PM
NecroFIesh's Avatar
Default Vtec Solenoid Valve Service
I'm swapping the K20 from my old RSX into my Integra and I decided to service the Vtec solenoid valve while the motor was out. Pasted from another forum...
Remember that old, rusted *** VTEC solenoid valve bracket...?Name:  KSwap13.jpg
Hurting. Can't be havin' that junk, so I decided tonight to replace the mounting bracket as well as the VTEC spool valve gasket and o-ring inside the valve itself. Check the pics...
There's a total of three 10mm bolts securing the the valve to the head. There's another shorter 10mm bolt that keeps the bracket secure against the valve. Once off, your head will look like this...
This is the valve from the other side, showing the filter on the bottom portion. Notice how the gasket has a snowman shape matching to where the oil channels are in the head...
Here's the OE bracket from '04...
OEM part number for the new bracket...
Old and busted and the new hotness...
OEM part numbers for the new spool valve filter and o-ring, respectively...
Use a fingernail or a small pick to pop out the old filter and then seat the new one in gently in it's place like this...
Next, you wanna unbolt the switch portion from the top of the valve. You may find it easier to get this switch loose while the valve is still mounted to the head. I didn't have any trouble with it already off however...
Remove the old o-ring the same way you did with the spool gasket and again, replace it with your new part gently. Make sure it seats inside the recessed area securely though...
Notice the star patterned bolts securing the solenoid portion to the valve ^^ You can remove this portion from the valve itself, however the o-ring inside has no part number from American Honda. I believe it's the same size o-ring as the switch portion, there's just no part number for it. It's up to you if you want to replace the o-ring there, I didn't however.
Finger tightening the valve back to the head...
And there we go, mounted back up and looking much better!
The VTEC solenoid valves aren't prone to failure very often, as I've seen in working with these vehicles for the past three years. As long as they're serviced at the correct mileage intervals, they hold up pretty well. Price on a whole new valve is well over $200, so be smart and keep yours clean and flowing smooth!
I also chose to use a wire brush to clean up the valve and surrounding areas on the head while I was at it. It may not look much different in the pics but trust me, it's much cleaner and smoother than before.
Hope to have the LS out tomorrow night as well as a full pulley replacement, pics to follow.
Old Nov 11, 2010 | 05:23 AM
turboteg2nv's Avatar
Default Re: Vtec Solenoid Valve Service
Good info.
You should've replaced the 3 bolts that hold the solenoid to the block lol... nice shiney new cover with 3 rusted *** bolts holding it on
Old Nov 11, 2010 | 08:36 AM
NecroFIesh's Avatar
Originally Posted by turboteg2nv
Good info.
I know right? I'll most likely be doing that soon.
Old Nov 11, 2010 | 10:41 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I just took mine off, hit it with the wire wheel, then painted it. Turned out great.
Nice work
Old Nov 11, 2010 | 01:46 PM
hawaiiancb74's Avatar
should have painted it because it will rust again in three days
Old Apr 8, 2011 | 08:05 AM
blknjep03's Avatar
NICE! GREAT INFO!
Old Apr 8, 2011 | 09:04 AM
DaveSi677's Avatar
good work!
Old Apr 11, 2011 | 04:16 PM
PittsburghNBP's Avatar
nice work
Old Apr 12, 2011 | 12:47 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The oil pressure sensor right below it is a VERY common leaker. Take a close look on your own engine, at your sensor.
Old Apr 15, 2011 | 06:08 PM
cloumep3's Avatar
Nice! Love the snowman!
Old Apr 17, 2011 | 11:11 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
the bolts are still rusted... lmfao
Old Feb 14, 2017 | 09:09 AM
kyle-99's Avatar
Replaced the gasket on my 2003 K24 solenoid this weekend. Was leaking profusely. The gasket was so hard and brittle it came of in chunks required a pliers to remove from the solenoid. So far, so good. No more leaks!
Old Feb 29, 2020 | 07:18 PM
Brandon Morson's Avatar
The bolts are sweet if you clean them up with a wire brush and reinstall them with a smidge of anti seize on the thread and torque it to spec. Once the motors in. You can't see this bit.
Flatland2D
Jul 16, 2010 09:14 AM
JDM_SOHC
17
May 15, 2007 06:11 PM
ExospeedAMcrx
Apr 6, 2007 03:09 PM
Master23
Jun 5, 2006 07:34 PM
