Red dust of death - timing belt
Old Nov 10, 2010 | 03:43 PM
jaysalti's Avatar
Default Red dust of death - timing belt
And the project continues...
May be a noob/uneducated question, but I recently started getting the occasional miss. This is not a new issue. I have had to replace the coil, ignitor, and whole housing before. This time I noticed the infamous red dust. I searched but wasn't able to find if this could be related to an over tightened timing belt.
I recently replaced the thermo and water pump and am wondering if I may have zipped it up too tight on reinstall. I have had no other issues other than some noise from the alternator. I know I have alternator bearings to replace (damn a new alt is expensive!!). pulled the plugs and it seems #3 isn't burning as clean as the rest... new dizzy is on the way and I plan to replace the plug wires at the same time.
Just wondering if the belt may drag a little too much to allow proper cam rotation. Thoughts appreciated!
Old Nov 10, 2010 | 09:55 PM
Chiovnidca's Avatar
Default Re: Red dust of death - timing belt
Red/brown dust in the distributor? That's an indication of a bad dist bearing. Nothing external will cause it.
Old Nov 11, 2010 | 04:27 AM
jaysalti's Avatar
Thanks for the reply. I didn't think so, but wanted to make sure... This is the third distributor i've had go bad.
tmessenger
Jun 14, 2010 05:58 PM
fleetw00d
Jan 3, 2010 07:06 PM
FSUseminoleEM1
Feb 28, 2009 07:33 PM
Shaguar47
Apr 6, 2007 07:39 AM
gotnothing
Jan 28, 2003 12:42 PM
