95 prelude vtec brake issues
Is the brake booster unit supposed to have two rubber o-ring seals inside where the master-cylinder goes? The guy put on the wrong m/c, non abs model, and ruined the seal that went on the rear of the master-cylinder. Bought a new one from Honda. Anyone know the bleed procedure on abs brakes on a 95 prelude? i have the bench bleeder.
Its only supposed to have 1 rubber ring. If you double them up(which is easy to do), the master cylinder rod won't return correctly and you'll never get the brakes bled.
ok, also i discovered that the brake-line is BIGGER, going to one side of the mastercylinder 5/16, and the other one is 3/16. problem: BOTH lines are 3/16, and one line won't screw on the m/c. suposeable, honda has upgraded the m/c unit and disgarded the old one? does anyone know about that?
