BRAKE PROBLEMS
Old Dec 27, 2007 | 01:18 PM
joeherdda6's Avatar
Default BRAKE PROBLEMS
IF I BLEAD THE BRAKES AND CHANGED THE PADS AND THE MASTER CYL AND THE BUSTER WHAT COULD KEEP MY BRAKE PEDDAL MUSHY?
Old Dec 27, 2007 | 01:21 PM
PrinceAli132's Avatar
Default Re: BRAKE PROBLEMS (joeherdda6)
In which order did you bleed the brakes?
Also what year is your car? Do you have abs?
And please don't type with the caps on its annoying as hell.
Ali
Old Dec 27, 2007 | 01:27 PM
joeherdda6's Avatar
i went from lert to right starting with the rear, no abs, and it a 93 da
Old Dec 27, 2007 | 01:33 PM
I always had good luck using the newer brake bleed procedure which is closest to farthest from the master cylinder.
Driver Front
Passanger Front
Driver Rear
Passanger Rear
Ali
Old Dec 27, 2007 | 01:38 PM
joeherdda6's Avatar
cool ill try that thanks
Old Dec 27, 2007 | 01:39 PM
And check to make sure you do not have any leaks in your lines and that your master cylinder resovoir is topped off.
Ali
Old Dec 27, 2007 | 04:11 PM
Dogginator's Avatar
Daisy... Daisy...
Getting all of the air out of the lines takes time. I assume that you are pressure bleeding with a friend?
Old Dec 28, 2007 | 03:00 PM
joeherdda6's Avatar
yea i had help and it stops fine now
Old Dec 28, 2007 | 03:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeherdda6 &raquo;</TD></TR><TR><TD CLASS="quote">yea i had help and it stops fine now </TD></TR></TABLE>
Ali
94jdmdb8
May 1, 2010 10:08 PM
InTheLBC20
Feb 14, 2009 05:26 AM
xiLLtegRax
Oct 20, 2005 12:35 PM
stareatsun
Sep 28, 2004 05:25 PM
