car cannot rev over 3,000 rpm
Old Sep 21, 2002 | 12:51 PM
ahc'monracing's Avatar
Default car cannot rev over 3,000 rpm
I am currently switching over to mpfi and all hell is breaking loose. Code 4 and code 16 is showing and my air suction sounds hollow and gruely!! I know how to get rid of the code 4 but still stuck on the code 16. I tried to drive my car but it backed fired at about 3200 rpm. I can't rev over 3000 rpm. anyone please help me. maybe a vacuum leak? don't know so any advice would be great.
thanks y'all
Old Sep 21, 2002 | 01:46 PM
SOUTHCREX's Avatar
Default Re: car cannot rev over 3,000 rpm (ahc'monracing)
the reving is prolly because you did not switch the tps wires around. Flip the two outside wires around.
Old Sep 21, 2002 | 05:13 PM
Default Re: car cannot rev over 3,000 rpm (TEAM GARAGE SHIFTDOWN)
which is the tps sensor wires? the 2 blue ones or the white ones?
Old Sep 21, 2002 | 07:34 PM
Wiz's Avatar
Wiz
Your problem is the code 4. Crank angle sensor. thats what is causing you to backfire and limit your rev to 3200. I too have this problem. in its advanced stages it will turn off on you randomly
Old Sep 21, 2002 | 08:52 PM
Louie B.'s Avatar
You did put the Si distributor in didn't you? and did you run the 2 extra wires from the dizzy to the ECU?
Old Sep 21, 2002 | 11:09 PM
AbaZ's Avatar
Make sure the distributor you are using is in good shape, I have seen lots of problems with Swaps similar to yours related to Distributor problems, either the igntior is bad, or the magnetic pickups on the TDC sensor/Crank Sensor are bad..
Try borrowing a extra distrib to see if it makes a diff... If not it is probably your wiring, but the dpfi to mpfi is a pretty straight forward wiring swap.
Jeff Frank
Nathan_volcom
Oct 21, 2011 05:49 AM
ADAMnQuickRDX
May 7, 2009 11:30 AM
Schaz
May 16, 2005 07:34 PM
winkelvtec
Feb 10, 2005 02:01 PM
Eresuncabron
Aug 12, 2004 01:01 PM
