h22 missing gears please help quick
Old Nov 9, 2010 | 10:21 AM
justnprsh07's Avatar
Default h22 missing gears please help quick
Alright I have a h22 tranny quafe, twindisc, and hancuff, dss 5.9 axles hubs and half shaft etc... 1st 2nd and 5th shift fine but third and fourth at 7500 rpm plus will not go into gear I know this has always been a problem with h series but I go to much into the tranny to go b series I've been told a pedal stop would help and syncro mesh trans fluid and straping the cables together would help so yal tell me some tricks to it or if any of those things have helped or hurt you
Old Nov 9, 2010 | 10:31 AM
turtleman321's Avatar
Default Re: h22 missing gears please help quick
Do you have your cables zip tied together? Also it could be syncro related. I would pull it apart and check the hubs and shift assemblies
Old Nov 9, 2010 | 10:36 AM
JayWest's Avatar
if you have a twin disk, chances are you need a clutch stop
what brand twin is it ?
Old Nov 9, 2010 | 11:06 AM
88ED8's Avatar
I knew I would find Jay in this thread!
Old Nov 9, 2010 | 11:08 AM
JayWest's Avatar
i see what you did there -_-
Old Nov 9, 2010 | 11:14 AM
88ED8's Avatar
lol, ijs...
Old Nov 9, 2010 | 11:42 AM
its a comp twin disc and I do not have a petal stop or cables zip tied together yet what type of fluid are yal running and has anyone had a problem with the dss half shaft not sealing into the transmition and causing it to leak
Old Nov 9, 2010 | 11:55 AM
h22 civic's Avatar
when was the last time tranny was rebuilt ?
Old Nov 9, 2010 | 11:58 AM
DxTrix's Avatar
Sounds like u have a oil leak problem maybe low fluid?
Old Nov 9, 2010 | 03:43 PM
kte324's Avatar
I am using a clutch stop on my comp twin as well as many others, but you know I got a b-series so it might be different Parish. Try using some of that Torco fluid.
orc1014
Transmission & Drivetrain
Mar 6, 2015 01:22 AM
mikec_CD5
May 11, 2010 05:34 PM
JasonST
Oct 5, 2006 06:41 AM
cyco252
Jun 6, 2006 12:22 PM
r1de4life
Jan 30, 2006 07:27 AM
