h22 missing gears please help quick
Alright I have a h22 tranny quafe, twindisc, and hancuff, dss 5.9 axles hubs and half shaft etc... 1st 2nd and 5th shift fine but third and fourth at 7500 rpm plus will not go into gear I know this has always been a problem with h series but I go to much into the tranny to go b series I've been told a pedal stop would help and syncro mesh trans fluid and straping the cables together would help so yal tell me some tricks to it or if any of those things have helped or hurt you
its a comp twin disc and I do not have a petal stop or cables zip tied together yet what type of fluid are yal running and has anyone had a problem with the dss half shaft not sealing into the transmition and causing it to leak
Sounds like u have a oil leak problem maybe low fluid?
I am using a clutch stop on my comp twin as well as many others, but you know I got a b-series so it might be different Parish. Try using some of that Torco fluid.
