my car just diedd.
Old Nov 8, 2010 | 08:10 PM
eazy64's Avatar
Default my car just diedd.
okay so i was driving like slowly. then all of a sudden i felt my car like slowdown and then it just died. then i tried turning it on and it cranks all sloww. and the batteries good dont know bout alternator. its too dark already.it wants to turn on like so close then it just diess.
cranking voltage read like 10 volts berely. what could it beee???
Old Nov 8, 2010 | 08:35 PM
BiG ChOr!Zo's Avatar
Default Re: my car just diedd.
make sure the rotor screw didn't fall off inside the dizzy...!!!
Old Nov 9, 2010 | 05:53 AM
eazy64's Avatar
nopee i checked that its still entact. is there a chance it could be the alternator???
Old Nov 9, 2010 | 07:25 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
With a fully charged battery the car should run without the alternator.
However, if you can't get it started, you wouldn't know... try jumping it. If it dies as soon as you take off the juice, it's the alternator (which should be able to supply enough juice to keep the car running without the help of the battery). If it keeps running, but won't restart without a jump each time, it's most likely the battery (or you didn't let the battery charge enough).
Old Nov 9, 2010 | 07:50 AM
TNFBandit's Avatar
sounds like battery problem
Old Nov 9, 2010 | 08:30 AM
EF9_RIDER37's Avatar
try switching the distributor off a good car i did it on my car and it did the same thing battery was good alternator was good but my alternator had given sht try that if and let us know what happens
Old Nov 9, 2010 | 12:50 PM
eazy64's Avatar
well i got a four year old batteryy, soo am thinking thattt. but if it is the battery then why did my car die while it was running??
my alternators newww. but it should at least start then die or somethingg like that.
is it possible my car could of skipped time cuz i just had my water pump and timing belt replaced like a month ago.
then again it could be something in the distributorr. am just trying to narrow it downn.
Old Nov 9, 2010 | 06:03 PM
eazy64's Avatar
okay heres the story i put my battery in my friends car and it did the same thing as mine. then put his in mine and it wanted to start better but still didnt. so replacing the battery what else could it be, distributor, alternator because the car died on me while drving????
Old Nov 10, 2010 | 10:10 AM
ef_dx_90's Avatar
Did you have bad mpg before? Or did it bog? TPS?
Old Nov 10, 2010 | 12:45 PM
tomnotty's Avatar
I had a similar situation(not regarding the battery though) where my car just died. Almost like it ran out of gas. The bearing in the distributor started to bind. It heated up so much that it melted the rotor and the rotor spun on its shaft. I was getting spark but it was all off time. I replaced the rotor and still no start. It ended up being the Ignition control unit, inside the distributor. I would get a good known distributor and see if that works, FIRST(if you can).
Old Nov 10, 2010 | 12:56 PM
eazy64's Avatar
nopee noone else has a Si that i know willl lemme borrow there distributor. is there any other way???
Old Nov 10, 2010 | 01:33 PM
eazy64's Avatar
mm nope i dont recall bad mileage. as for bog i dont know what that is or tps....
Old Nov 10, 2010 | 04:01 PM
eazy64's Avatar
okayyy my batteries alll charged uppp and still nothingg.
it has like a slowww, uglyyy crankkk like if something fell apart in the engine..
Old Nov 11, 2010 | 08:00 PM
eazy64's Avatar
doess anybody know if these are symptoms of an Out of time car or mistimed????
Old Nov 11, 2010 | 08:31 PM
rwdsohcef's Avatar
I sure would check the timing belt, sounds like the motor is struggling to turn over due to bad valve timing letting compression out. Head gasket could let water into a cylinder and hydrolic the motor, intake gasket has the ability to do the same not likely. I am a mind reader as well. So here I go. It is raining where you are, you have a cold air intake and you sucked up to much water, so says the rwdsohcef guy
Old Nov 11, 2010 | 08:53 PM
eazy64's Avatar
danngg thats pretty scary. u pretty much hit the nail on the head except for a couple things. yess it is raining i got a cold air intake but i never recall driving in the rain. and i got a hard plastic cover protecting itt.
ALLDAY-24
18
May 3, 2011 08:25 AM
aSDthing
Feb 12, 2008 06:03 PM
IHTFP
Jul 30, 2006 07:01 PM
ITR-00-1457
Apr 14, 2004 01:05 PM
Martaigne
Jul 14, 2002 04:19 PM
