lube for engine rebuild?
block is back from the machine shop and im about to start re-assembly. just wondering what kind of lubricant you use, if any, on the internal pieces. thanks.
um, you should be using an engine assemble lube. ususlly a moly based lube or something. the lube is more of a grease than oil so it will stay where you up them. dont use engine oil cause they will jus run out and you'll have a dry engine. go buy some engine assembley lube.
for tk
[Modified by Chois i-VTEC, 4:00 PM 9/21/2002]
for tk
http://www.redlineoil.com/redlineoil/asslbeti.htm
http://www.torcoracingoils.com/products/index.htm
we use either Torco MPZ engine and cam assembly lube or Redline assembly lube.
devin0606
Mar 21, 2017 12:45 PM
DeDonDeRosa
Apr 11, 2003 10:48 PM
