WEIGHT REDUCTION
Old Nov 8, 2010 | 02:17 PM
TEAM ASSASSIN SI's Avatar
Default WEIGHT REDUCTION
ok so im in the middle of weight reduction in my ek hatch i think i got to everything i could think of with out cutting the chassis lol. so i though lets talk about this subject what have you guys done as far as weight reduction.
Old Nov 8, 2010 | 02:42 PM
Garage 808 Hatch's Avatar
Default Re: WEIGHT REDUCTION
sound deadening material, padding under carpet, sheet metal behind plastic panels, pin windows up and get rid of regulators, and door bars. heater motor and core, etc. if you're serious
Old Nov 8, 2010 | 02:43 PM
JDM JEFFREY's Avatar
what class ?
how much does you car weigh?
how much weight do you need to remove?
wiring,door bars,brakes,everything that is no longer used and be taking out
heat,blower motor. this list go on...
Old Nov 8, 2010 | 04:31 PM
kte324's Avatar
I have done about everything above except the windows. I plan on doing lexan and getting rid of them heavy windows and regulators.
Old Nov 8, 2010 | 04:32 PM
just make sure the class your running in lets you run lexan windows
Old Nov 8, 2010 | 04:59 PM
Mikeyto's Avatar
lexan windows is only allowed in hot rod and above
Old Nov 8, 2010 | 05:35 PM
kte324's Avatar
Yeah, its pretty much a "hot rod" now. It doesn't have a dash and is missing a few class mandatory items.
Old Nov 9, 2010 | 11:33 AM
im running in sfwd so lexan not an option as it seats with 6 point cage 2550 lb.im trying to loose 100lb so far im up to 50lb by gutting doors and airbags is pretty much a track car now so i really don't need heather assembly but how much does weight is it worth removing?
Old Nov 9, 2010 | 12:54 PM
Poootie's Avatar
how much do you( the driver) weigh.. Because i had an EK and it was 2356lbs with me in it... And i didn't cut anythingggggg.. And i still had heat and the back and passanger belts, rear bumper support and power doors.
Granted you have a 6 point. But damn , why is it 2500+lbs?
Old Nov 9, 2010 | 01:14 PM
Poootie's Avatar
Ok!! Lets see what you HAVE to keep to be legal for SFDW!!
*headliner
*passanger and driver seat
*rear plastics
*carpet
*all OEM glass
*door pannels
^^ That being said , everything else is fair game..
Front and rear bumper support, manual doors which should have came on that car from the factory,the rear seatbelts and buckels,if you get a fuel cell like the NRG Tech one you can save about 14lbs over the stock one, lighter wheels like skinnies,sound material,heater core is you can stand being in a soda can for a car in -32*, swapping to a steering wheel without a airbag.
At the extreme you cna cut the sheet metel thats behing the rear plastics. But seriously? Why? when you have a turbo car.
Better option is CF parts (hood, hatch, Fiberglass front )
Old Nov 9, 2010 | 01:27 PM
I WEIGHT 140 POUNDS WET LOL dawm your ek was light as hell
Old Nov 9, 2010 | 01:28 PM
reddcoupe's Avatar
i chopped the hell out my ek coupe an its still heavy at this point so much is gone not sure what class i qualify for
Old Nov 9, 2010 | 02:58 PM
Poootie's Avatar
i was 140lbs at the time also.. I'm 160lbs now ( i have to take two $hits b4 i drive the thing). I need to go on a jockey diet!
I still had a tonnn of stuff to take off , if needed! I was just too lazy to do it..
I seen your car at Fall Nat , sounded gooood. I think you need to focus a lil more on setting the suspension up better, and scaleing the car. What does you 60's look like?
I don't see you needing to cut the car whatt soo everrrr!
Ps: I just seen your sig.. Thats a hugee MPH for that ET! I assume you are spinning.
Old Nov 9, 2010 | 03:18 PM
redboost10's Avatar
you should be able to get a sfwd ek hatch to 2250...i got mine down to 2236. thats with glass still of course.
Old Nov 9, 2010 | 03:43 PM
Poootie's Avatar
Old Nov 9, 2010 | 04:27 PM
2point2's Avatar
crx
Old Nov 9, 2010 | 05:20 PM
2literCR-X's Avatar
Originally Posted by 2point2
crx
LoL
Old Nov 9, 2010 | 08:36 PM
unusual71's Avatar
trunk support webbing, hood support webbing
extra wiring adds up fast
rubber/insulation mat that is strapped to the firewall
and the rest of the sound deadening tar, too.
The heater core
abs, a/c, p/s,
and extra brackets
Old Nov 10, 2010 | 06:23 AM
88ED8's Avatar
crx
What does yours weigh?
Old Nov 10, 2010 | 01:00 PM
Ls_dx's Avatar
I wish I still had a heater
Old Nov 10, 2010 | 01:09 PM
HamiltonRex's Avatar
I gave up on weight reduction when I decided to drag race with a DSM.
Pulling apart your wiring harness and removing everything out of there that you deleted. Thats a ton of wiring.
All sound deatening, use dry ice to get the stuff off the floor, it works very well, and removes it clean.
Just basically removing any misc things you don't need, seatbelts, etc, heatercore, all your ducting under the dash.
Then start using some lightweight parts, like cf doors/hatch/hood/fenders, remove your bumper beams, etc.
Lighter brakes, lighter wheels, it can get expensive though to shed that last bit of weight.
Old Nov 10, 2010 | 03:12 PM
spinning like crazy plus tranny giving me a hard time i've been catching 1'66 1'68 60' with the power the car made it should be in the 9's hopefully i can get there before the year ends.
Old Nov 10, 2010 | 03:39 PM
Poootie's Avatar
what are you doing for boost controle?
Old Nov 10, 2010 | 03:46 PM
narfdanarf's Avatar
My em1 is pretty bare...no heater core, no rear plastics, no sound deadening, no firewall mat, only a driver's seat, gutted the innards of the dash, removed a hell of a lot of wiring and extra bolts and stuff and it still weighed 25xx without me...I'm going to replace the driver's seat with a kirkey, I have rear skinnies to put on, gonna pull the sunroof out and put an aluminum plug in it. Don't really know what else to do besides door bars.
Old Nov 10, 2010 | 03:55 PM
boosted2.4's Avatar
^^^ How is your car still that heavy? My em1 with basically the same weight reduction (still power windows, still has sunroof, all the wiring, and all seats but driver is a kirkey) and it weights 2320 with a full tank of gas and my street tires without me in it.
