BBK performance IM or Victor X
Hey fellas I am looking for a little insight on these 2 products. I have seen numerous cars running the Victor X and making good numbers for higher boost setups and high revving motors. I have also been told about BBK performance who makes a IM and portmatched TB. They both look like nice products but I am looking for experience with it. I know the victor makes power 7-10k, but I wont be turning much past 9k with my setup so picking up midrange is a thought in my mind. Any opinions or experience?
They look almost identical in dimensions and how their built.
http://www.bbkperformance.com/produc...parts-398x.jpg
Thanks for the input
EDIT: I guess i should post my future goals. 500whp on pump gas and 600whp on c16 or 110 on a sc6262 turbo .82AR or a Garrett GT35R. Undecided yet. It will be a Benson sleeved 84mm GSR block fully built top to bottom.
I know MarineSol was running it on his setup and was making 600+whp with it. I just want to see if anyone has comparisons or tuning/dyno experience on the 2.
i am running a 70mm RPM services throttle body...
635whp at 8500 rpms... the car started to lean out... if you keep like line straight on my dyno graph... it would have been in the 670whp range (theoretically) but at that point who cares...
however, this was with a FULL 3" exhaust vibrant resonator and borla mufflers
Dont quote me on this but I believe the VictorX is 68mm the bbk is actually 70mm inlet but from just looking at it the victorx looks like the plenum is larger than the bbk but idk
I am using 1000ID's at 90psi base pressure (fuel lab regular) with the walbro intank and bosch 044.... i dont know why it ran out of fuel... i had to get off the dyno do to time restraints... turning up the base pressure probably would have helped...
im pretty much done with the car... 435whp at 13psi keeps me happy and reliable....
I know the 2mm on the TB wont make a noticable difference in this situation. I guess ill just do some reading here and there and everywhere and see what people have come up with. Hands down the VictorX has proven itself
ahobbs made over 650 with the victorX IM
id just pick which one u can find for the best deal... i dont see that as that big of a restriction either way...
Thats the thing, I can get the BBK for $275 pretty much anywhere, and their TB for $250 but with not TPS. All the places selling their products have the same price. I have found the VictorX for as low at $240 all the way up to $400. With a Blox TB for $250 w/ the sensor is cheaper. I plan on going 68mm and running 2.5" charge piping. I dont see the need for 3"....unless someone can convince me differently.
maybe... i can find one
if someone would like to donate one (i would mail it back) i will do a dyno test with my car on pump gas... i made 435whp at 13psi (wastegate)... i would be interested to see the diff....
