mpfi injector wiring help
Old Nov 4, 2010 | 05:57 PM
chrysanderson's Avatar
Default mpfi injector wiring help
ok heres my situation. im doin a mpfi swap and having alot of problems. im tryn to wire up my injectors an read i need to have a injector resistor? is that neccecary for me to wire them up? an does anyone kno a site that says were to put the wires on the ECU?
i have look around. ive hit the search button sooo many times.found lil info that help. been tryn to do this for close to a month now so anythin helps
Old Nov 4, 2010 | 06:57 PM
BiG ChOr!Zo's Avatar
Default Re: mpfi injector wiring help
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old Nov 4, 2010 | 08:57 PM
efjones9's Avatar
depends on what injectors ur using, ill make u a separate injector wiring harness that makes everything almost plug and play for 25 shipped lmk!
Old Nov 5, 2010 | 12:28 AM
im using obd1 stock z6 injectors. i ended up wiring all the injectors to the ecu, wiring all the yellow/black wires to a wire that gets 12v power. idk if it works or not cause i cant get the car started.
i have to figure out were all the hoses an plugs go.
Old Nov 5, 2010 | 04:07 PM
efjones9's Avatar
ok. there are 2 blk/yel wires that come from ur 2 injectors that are on the dx.std harness. solder those 2 together and from that, add a 3rd wire and run that 3rd wire to the yel/blk wires that come off the inj. plugs and solder them all together. ill draw u up a diagram to explain better
Old Nov 5, 2010 | 04:47 PM
efjones9's Avatar
check my photoshop work lol
i hope this helps...there should be a total of 5 wires connected together
Old Nov 5, 2010 | 06:21 PM
dohc4life's Avatar
seriously lol google is your friend use it
Old Nov 5, 2010 | 08:10 PM
hatchet_honda's Avatar
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Nov 7, 2010 | 05:50 PM
haha yes that helped actualy. straight artist over there haha
Old Nov 7, 2010 | 05:55 PM
Originally Posted by hatchet_honda
i did all this. car still wont start up
Old Nov 7, 2010 | 06:29 PM
JeffBro's Avatar
Double check the distributor wiring. If somethings not right there it won't fire at all
Old Nov 7, 2010 | 06:54 PM
ive checked it. swapped the white wired around cause its hard to tell what one is bigger still didnt work. it does the same thing it did when i blew my head gasket.
Old Nov 7, 2010 | 07:15 PM
efjones9's Avatar
when u prime ur fuel pump does ur main relay click 2xs?
Old Nov 7, 2010 | 07:35 PM
i have no clue haha im totaly new to this stuff.
i kno i have fuel pressure.i flip the fuel pressure switch an fuel goes in one side of the fuel rail an outside tha other haha
Old Nov 7, 2010 | 09:08 PM
efjones9's Avatar
look for it here. and put ur hand on the relay turn ur key on the 1st position and u should feel it click then ull hear ur fuel pump prime and then it will click agian. if it doesnt review ur wiring
http://www.tegger.com/hondafaq/mainr...8-91-civic.jpg
jdm95
Nov 23, 2009 04:49 PM
Si Integra
Jul 7, 2005 07:56 PM
Hondatec38
Mar 4, 2003 08:57 PM
