b18c1 building bottom end for boost piston ration 9.7.1 or lower?
Old Nov 3, 2010 | 05:59 PM
dvjr84's Avatar
Default b18c1 building bottom end for boost piston ration 9.7.1 or lower?
im ordering manley h beam rods and wiseco 81.5mm pistons with a 9.7.1 ratio. my question is should i go with a lower compression ratio?
Old Nov 3, 2010 | 06:03 PM
TheShodan's Avatar
Moderator
Default Re: b18c1 building bottom end for boost piston ration 9.7.1 or lower?
nah..you're just fine unless you live in an area with 91 octane swill.
Old Nov 3, 2010 | 06:06 PM
dvjr84's Avatar
some ppltell me i need to lower it and some say ill loose some throttle response? is lower better or more relaible?
Old Nov 3, 2010 | 07:02 PM
2k.civic.si's Avatar
what fuel do you plan on running this motor on? how much boost? power level? cams?
Old Nov 3, 2010 | 07:47 PM
jetspeedz's Avatar
You are fine, im 9.8:1 and put close to 500 down with pump gas, if you plan on running race gas i would suggest lower, keep in mind cylinder pressure is cylinder pressure whether you run high comp/less boost or low comp/high boost
cheers
Old Nov 3, 2010 | 07:50 PM
dvjr84's Avatar
Ater the past few hours of searching i decided to go with 9.1 cp pistons. I always use 93 shell or sunoco but Im reading that ratio is more reliable. I believe i have type r cams and intake mani. Im hoping to push 19psi
Old Nov 3, 2010 | 07:52 PM
jetspeedz's Avatar
19 psi is no issue with 93, you would get more HP if you ran higher compression and still be safe, if it's a daily driver your much better off going higher cp but up to you. Don't believe me call up Shaun at Church tuning.
good luck
Old Nov 3, 2010 | 08:05 PM
TheShodan's Avatar
Moderator
Reliability is in your tuning, not your compression.
I'm at 10.4:1 on my turbo car for 7 years on 93 octane
I'm at 12.5:1 on my NA car for 4 years on 93 OCtane.
How you build and who builds is the X factor. not your compression
Old Nov 3, 2010 | 08:11 PM
dvjr84's Avatar
jeff evans is dyno tuning it. So should i use 9.7.1 or 9.1
Old Nov 3, 2010 | 08:56 PM
jetspeedz's Avatar
if its a daily driver go with the higher cr which will make driving around town much more fun, that is my opinion. Like Pete said its all about how its put together and the tune.
Old Nov 3, 2010 | 09:05 PM
sik96teg's Avatar
how much power are you going for? I saw you said 19psi but that doesnt saw how much power your going for. I would go 9.7:1 comp. If you plan on going for insane power than 9.1. I daily drive my teg at 10.2:1 comp pushing just over 300whp.
Old Nov 3, 2010 | 09:13 PM
dvjr84's Avatar
500hp
Old Nov 3, 2010 | 09:15 PM
dvjr84's Avatar
cp 9.8.1 or 9.0.1? Wiseco was 9.7.1 but im using cp. just wanna make the best decision
Old Nov 3, 2010 | 09:18 PM
dvjr84's Avatar
i think i should be good with 9.8.1
Old Nov 3, 2010 | 10:38 PM
hybrdthry911's Avatar
cheers
its not quite that simple, hence why you cant just run super high compression on pump gas to match an even mild turbocharged 300whp. pressure created by the turbocharger can be cooled off before entering the combustion chamber as opposed to higher compression where there is no way to avoid an increase in temperature in the cylinder.
Old Nov 4, 2010 | 07:39 AM
dvjr84's Avatar
so i ordered the cp 81.5mm 9.0:1 manley rods this morning after calling a few tuner shops. Since its a street car it would be better im told.
Old Nov 4, 2010 | 07:59 AM
Schister66's Avatar
Man U FTW
So...you have 93 octane and are going to get a great tune. I would say something ~10:1. The only reason to go lower is if your goals exceed the ability of the tuner or if the fuel in the area is of a sub-par grade. You seem to have neither of those issues and should therefore go with something a little higher.
Old Nov 4, 2010 | 08:44 AM
jetspeedz's Avatar
The issue is the efficiency of the intercooler, if it actually increases the density of air then yes you are correct, also keep in mind that a turbocharged engine runs hotter in general compared to a NA setup so the charged air can sometimes just offset the difference and your back to where you started. Tune of course has a lot to do with it but given tune is equal in both setups you will be surprised how close the EGG, ECT temps are of an off-shelf turbo kit compared to a all motor NA setup.
cheers
slowcrx954
Engine Management and Tuning
Sep 15, 2010 03:01 PM
FullBoostAhead
Feb 10, 2004 01:51 PM
rb08
Aug 26, 2003 07:52 AM
-iLLuZioN-B18C1
Mar 4, 2003 04:46 PM
Adampops
Jan 7, 2002 10:15 AM
