Where does this Vacuum line go...
Old Nov 1, 2010 | 04:26 PM
ExtraBlackRex's Avatar
Default Where does this Vacuum line go...
The Car is a 2002 Honda Accord, 4cyl with the ULEV VTEC motor in it..here is the vacuum line, coming from a sensor on the fire wall on the right side (Passenger side) of the car...
This is a shot of another hose I think it connects to running across and ontop of a bracket on top of the transmission..It MAY have had a check valve in it, the ******* who did the mount on my girls car snatched the hose out and forgot where it goes and lost the plastic piece that was in it...
Any help would be appreciated, i've been trying to find diagrams for this car and motor online but i've failed thus far...thanks!
Old Nov 1, 2010 | 08:15 PM
Elvis1977's Avatar
Default Re: Where does this Vacuum line go...
It might go to the rear motor mount. Check to see if hose is disconnected at rear motor mount.
Old Nov 1, 2010 | 08:31 PM
02 accord's Avatar
Yup, goes to the rear mount. And it's funny since my hose looks exactly the same, with a bolt stuck in it. I did that when I swapped to a manual trans and mount.
Old Nov 2, 2010 | 11:01 AM
Ok so does this hose sit ONTOP of the rear mount or runs long aside the side or bottom?? I don't need anything but a clamp to put it back on right?
Old Nov 2, 2010 | 12:06 PM
02 accord's Avatar
From what I remember, it goes around to the bottom of the mount.
Old Nov 2, 2010 | 12:08 PM
Elvis1977's Avatar
I think the hose goes to the bottom of rear mount. You just push it into the connector.
fxfeguy
Mar 10, 2019 02:35 PM
dishjuarez
Aug 31, 2016 09:28 AM
VeeSykkz
Apr 8, 2016 11:43 AM
civic565
Mar 21, 2011 05:46 PM
mherrcat
Feb 16, 2011 04:17 PM
