welding magnesium
Old Nov 1, 2010 | 03:13 PM
russianvr4's Avatar
OG Fabricator
Default welding magnesium
i got an old school 80's fuel injected magnesium intake manifold off a corvette race car thats set up as individual stacks. the coolant passages got corroded out and it needs to be repaired.
i know its a pretty dangerous material to heat up.
has anyone welded it? any tips?
Old Nov 1, 2010 | 03:30 PM
9bells's Avatar
OG Fabricator
Default Re: welding magnesium
It's not a far cry from aluminum. The arc has a green glow to it. It has to be very clean, and so does the filler rod. You need to know what kind of casting it is to fix it right. Should have some numbers on it like AM60 a or b, or amz91 with a few different letters, or just z91, etc.
The filler rod is expensive, but hopefully you have some. Don't take it out of the box/container until you are going to use it. It oxidizes real quick in the open and doesn't weld great after it happens.
Old Nov 1, 2010 | 03:36 PM
russianvr4's Avatar
OG Fabricator
whats the realistic danger of it catching on fire? what do i do in case that happens?
Old Nov 1, 2010 | 04:24 PM
9bells's Avatar
OG Fabricator
It doesn't catch on fire when you weld it!!!!
Small filings from a die grinder or grinding disc will though. Just make sure the area is clean of filings, and you are good to go.
Old Nov 1, 2010 | 04:57 PM
russianvr4's Avatar
OG Fabricator
ok cool i was under the impression this would be like playing with liquid gas, got me intimidated quite a bit lol.
Old Nov 2, 2010 | 12:16 AM
ScorpioMk's Avatar
Since im wondering about welding something like this, has anyone ever welded a regamaster or spoon wheel thats cracked? Friend has one that needs welding and dunno what rod would be best, seen somewhere its an aluminum/magnesium blend but who knows.
Old Nov 2, 2010 | 03:14 PM
jere's Avatar
I would think that if the wheel is cracked it is too far gone especially around the lug holes or by the end of a spoke. The heat would make things worse. But I could be wrong
Old Nov 2, 2010 | 03:16 PM
russianvr4's Avatar
OG Fabricator
who said its a wheel?
part in question is an old school kinsler ITB intake manifold for a chevy big block.
Old Nov 2, 2010 | 04:15 PM
ScorpioMk's Avatar
He is talking about my post.
The crack is on the bead of the wheel, definitely not to far gone by any means. Ive welded multiple wheels in that area with success but havent welded a regamaster/spoon wheel before.
Old Nov 3, 2010 | 01:21 PM
CRMB's Avatar
OG Fabricator
With your penchant for creating explosions, be sure to video tape it for posterity.
I'm sure you'll be fine.
Old Nov 3, 2010 | 09:08 PM
Top Ramen's Avatar
Truth. It's crazy how fast it oxidizes.
Old Nov 4, 2010 | 06:54 AM
russianvr4's Avatar
OG Fabricator
LMAO!
for the record i've only had one explosion, it was miniature too
Old Nov 4, 2010 | 08:44 AM
qksl2's Avatar
Dear Eugene,
Please don't go all cold war on yourself.
Thanks!
Ian
Old Nov 5, 2010 | 12:12 AM
TIGboy's Avatar
wear a respirator and prep it really good.
Old Nov 5, 2010 | 12:42 PM
N1 Andy's Avatar
R.I.P. Andy
I was under the understanding they were just Aluminum. Its the "shot alumite" finishing process that gives them their unique color. Who has a set of regamasters?
efinfroman
Dec 22, 2011 07:21 PM
toubaby2
Jan 13, 2009 10:24 AM
boost_aholic97
Welding / Fabrication
22
Sep 13, 2007 09:04 PM
autosport7
Nov 22, 2006 11:28 PM
Fred Allen Burge
12
Apr 4, 2006 10:23 PM
