Honda CR-V & Element 2WD & 4WD Element & CR-V
High mileage CRV, anything to look for?
Old Oct 31, 2010 | 02:57 PM
fernando.'s Avatar
Default High mileage CRV, anything to look for?
I'm looking to buy a 2000 4x4 CRV for a winter car. This thing is mint, I mean there's no rust on the body or under it, the interior is clean and doesn't smell, the motor runs great, tranny shifts smooth and the 4x4 works. Only one problem, it's just shy of 186xxx miles. Are there any major problems to look for on these? Other than timing belt, regular stuff, ect. Thanks!
Old Oct 31, 2010 | 03:22 PM
J_DC5's Avatar
Default Re: High mileage CRV, anything to look for?
There is no timing belt but they do have a chain and they do have issues with them if
they lacked on oil changes . Take it some where and get it inspected but they are pretty solid .
Old Oct 31, 2010 | 03:24 PM
fernando.'s Avatar
Wait, what? The B20 in those CRV's don't have a timing belt?
Old Oct 31, 2010 | 03:36 PM
J_DC5's Avatar
Sorry i was thinking 02 . yes the B20 has a timing belt .
Old Oct 31, 2010 | 05:56 PM
eghatch4sale's Avatar
Since when is 186k high ? For 11 year old car
Old Oct 31, 2010 | 07:28 PM
norcalem2's Avatar
I would look at all these things and see when it was replace and if they need to be replace.
check Tranny fluid
check Rear Diff fluid
Change Engine oil
Check Spark Plugs
Check Air Filter
Check Coolant
Check struts
Check Bushing
Check Endlinks
Also if the car has loud ticking noise coming from the cams. Then you are going to need a valve adjustment.
B20 motor has Timing belt
Check timing belt and water pump.
Old Oct 31, 2010 | 07:45 PM
gsrintegra175hp's Avatar
my 98 has 215k on it, my moms has 275 on it, they both run like champs.. they sway bar links have gone out of both mine and my moms around 200k but its not bad to change them. i changed the timing belts as soon as we bought both of them so i diffident have to worry about it not being done.
Old Dec 16, 2010 | 03:21 PM
verycooljdm's Avatar
Usually cars like that are well maintained. They wouldn't drive long distances if their car would break down. However check for all the usualy replacements, imo.
Snowwhitecoupe
Oct 21, 2011 05:13 PM
mikeintegra93
Dec 10, 2010 07:29 AM
gamby
Aug 1, 2005 07:49 AM
Cosworth
10
Oct 18, 2003 02:32 PM
wm5holla
Apr 26, 2003 12:42 PM
