need longer studs on head for intake manifold
the studs for the skunk2 intake manifold are short. i like to do things right, so i was wondering if anyone could point me in the direction to find longer ones with same threading, id like to get at least a half inch longer. i have a b18c1
for got to say i am using a hondata gasket also
nvr said skunk2 shipped out studs. some oem studs only allow the nut to grab a few threads not enough in my opinion when i have solid mounts, i want things right. i am also using a hondata gasket thats is thicker than oem
the only reason you are having issues with the length of the studs is because of the hondata intake gasket. if you were using a stock gasket there wouldnt be a issue. if you are looking for a easy solution you can use the studs that the throttle body mount with on the intake manifold. they are longer and work perfect. so go to the junk yard and grab some. hope this helps
Yes both intake and exhaust use the same studs. They can be found at almost any hardware store. M8x1.25 and get them around 50mm since factory is 37mm. Mine were in a drawer labeled automotive studs and were $2.60 each. Advance Auto also sells them in a pack of 10 or 12 for $13. I just had to get some the other day for my blox manifold.
fizic
11
Mar 26, 2009 07:49 AM
