Evo 3 16G turbo advice....
I've been searching online for a long time now trying to find some advice on the Evo 3 MHI 16g turbo, but I can't find enough about this turbo on a honda to make a final decision on it. I was wondering if it was going to hit my power goals. This is my setup:
B16 head:
-Supertech dual valve springs
-Supertech Ti retainers
-Ferrea race valves
-GSR cams
GSR Block:
-Eagle H beam rods
-Supertech 9.1:1 forged pistons
-ACL race bearings
Fuel:
-Walbro 255 fuel pump
-750cc RC injectors
-Blox FPR
-AEM fuel rail
Pretty much a fully built poorman's type r. My goal is between 300-350 whp. I was wondering if the Evo 3 16g turbo will stand up to these numbers even at 8500 rpms or will it run out of breath? Thanks for any opinions.
B16 head:
-Ferrea race valves
-GSR cams
GSR Block:
-Eagle H beam rods
-ACL race bearings
Fuel:
-750cc RC injectors
-Blox FPR
-AEM fuel rail
Ya i bought an adapter plate to run this turbo. I want it to spool quick, which this turbo will do, but I just wanted to know if it would meet power goals ok.
that turbo will make good power especially for its price. What I do recommend is taking of the exh side and doing some porting on the exh housing as the biggest restrictor of flow is its housing. Housing are a dime a dozen for thsoe turbos so dont be scared to give it a good porting and smoothing.
Not sure if youre running an internal or external gate but if running internal you can channel a little more towards the internal gate to help boost control a bit better.
It will make 320+ i know of for sure and thats on a dsm motor, and im sure on a honda motor it will make a tad more.
I have a lot of experience with the EVO III 16g on my integra. The last setup was a stock GSR and it made 297whp and 258wtrq at 18psi on a Mustang dyno. The turbo still has plenty more in it as well. The turbo made peak power around 8K if I remember correctly.
Great! Ya i'm still deciding on if i wanna weld the flapper door shut and go external. Those are the exact numbers that I wanted to see lol.
Definitely weld the flapper shut and go external. When I had the EVO III 16g on my built LS motor boost creep was a pain in my a$$! Went with a Tial 38mm external off the manifold and solid boost ever since!
