car leaking oil? Need Help.
Old Oct 29, 2010 | 07:48 PM
smokkee's Avatar
Default car leaking oil? Need Help.
I put together my gsr engine and it keep leaking oil at the head gasket on the dizzy side. I have no idea what it could be..
I did everything correctly, and compression test it to be fine. car drive fine..
Anybody knows what it can be..
Old Oct 29, 2010 | 08:22 PM
wtf_is_jdm's Avatar
Default Re: car leaking oil? Need Help.
and you are positive it is not coming from the Cam Seal.... or maybe the Vtec solenoid?
Old Oct 29, 2010 | 09:02 PM
smokkee's Avatar
I've check everything and change everything...
Old Oct 30, 2010 | 07:41 AM
wtf_is_jdm's Avatar
Well..... I guess if you are leaking out of the Head gasket area..... time for a swap. (head-gasket)
Old Oct 30, 2010 | 08:30 AM
smokkee's Avatar
could it be that the machine shop did a poor job and its uneven?
Old Oct 30, 2010 | 01:28 PM
BiG ChOr!Zo's Avatar
check the dizzy o-ring...!!!
Old Oct 30, 2010 | 03:31 PM
smokkee's Avatar
change dizzy o-ring already, and still leak oil..
Old Oct 30, 2010 | 05:30 PM
wtf_is_jdm's Avatar
well....... use a crap load of rtv to hold it for now and get it to a shop..... because apparently anything we suggest to you have either been replaced.... or you are positive that there is no leak in the given suggestions. I am starting to get tired of seeing these help threads with no answers. Really is more or less a pain in the a** when using the search engine.
Old Nov 2, 2010 | 03:14 PM
Rigginit's Avatar
Agreed. clean the oil off that has already leaked. If in fact it isn't coming from inproper installation of what you have already installed trying to fix it.. It only leaves the gasket itself. Pull it back apart and check the surfaces with a straight edge. Even the cheap Haynes manuals walk you through this process. As for the unanswered threads in search, would be nice for mods to go through and delete a lot of the useless stuff. Obviously not the ones with recommendations as to what would help, but the ones that are too old and have no responses or the ttt spam ones. That would be so nice haha.
CaliforniaDad
Mar 22, 2013 10:10 PM
DIABOLICGSR
Dec 29, 2008 09:53 PM
jdm ek9 101
May 10, 2007 11:30 AM
98GreenTegGSR
Dec 18, 2006 11:56 PM
PatrickGSR94
Mar 5, 2003 10:02 PM
