FS: Honda/Acura DA/DB Parts
Old Oct 29, 2010 | 05:23 PM
DB2-R81's Avatar
25 Year Member
Default FS: Honda/Acura DA/DB Parts
2 X Earls Speed–Seal Hose End, Hose Size –3, 90 degree Non–Adjustable Banjo, $8.00 each
1 X Earls Speed–Seal Hose End Male Tee Hose Size –3, $12.00
3 X Earls Speed–Seal Hose End, Hose Size –3, $8.00 each
2 X Earls Speed–Seal Hose End, Hose Size –3, 30 degree Non–Adjustable Banjo $8.00 each
93 Integra GSR Master Brake Cylinder $45.00
93 Integra RS/LS/GS Proportioning Valve $32.00
B Series Throttle Body, Taper Bored Opening 65 mm - 60 mm $28.00
Fuel Rail and Injector Harness Cover, fits ITR manifold, comes with custom built Harness Cover adaptor
$15.00
B16/B17/B18 Stock Cam Gears $8.00
SS 2.0 inch Mid Pipe with Mandrel Bends $32.00
Autometer Pro Comp UltraLite Oil Pressure Gauge 2-5/8”, $20.00
16 Wheel Lug Studs, Honda Part # 90113-SA0-025, Fits Civic, CRX, Integra, CRV, Del Sol, TSX, TL, Accord ……. $10.00
93 Integra Stock Rear Anti Sway Bar Endlinks and 14.7mm Bushings $4.00 per set
93 Integra Spare Tire Bolt and Hold Down Washers $2.00
93 Integra Ignition Switch $15.00
93 Integra Hood Latch $12.00
New 4 Metal Valve Stems $4.00
90-93 Integra Prothane Rear Motor Mount Inserts fits: RS, LS, GS and GSR $8.00
90-93 Integra Map Sensor, firewall mounted $14.00
90-93 Integra Rear Defroster Switchs $3.00 each
90-93 Integra Left Inner Door Handle Plate Graphite Black $3.00
m_sasso@shaw.ca
Charlie Moua
Dec 17, 2010 12:27 AM
VisualAutoMotoring
Sep 4, 2008 07:37 AM
Cprace1
Oct 16, 2007 01:39 PM
descartesfool
May 15, 2007 05:07 AM
