Transmission & Drivetrain Gearboxes, Differentials, Clutches
not going back together
Old Oct 28, 2010 | 06:05 PM
OddityDX's Avatar
Default not going back together
I just ripped down a 96' gsr trans that I just picked up. Wanted to check the syncros and what not. Everything is in good shape. I went to put it back together and it will not go. When I take out the main shaft thrust washer it fits and seals just fine. Am I doing something wrong? no new parts just checkin it out and cleaning. I will double check the main shaft in the morning just to make sure its together right. So it should go together without a problem right.
Old Oct 28, 2010 | 06:43 PM
Aquafina's Avatar
Default Re: not going back together
Something is on upside down on the mainshaft if taking out the spring washer solves the problem.
Old Oct 30, 2010 | 07:24 AM
OddityDX's Avatar
Well I don't know what I did but it's together now. I took the mainshaft apart and then put it back together and It works now. So who knows.
4hammers
Classic Hondas
May 18, 2010 11:02 PM
starion88esir
Mar 24, 2010 11:18 PM
slo4door
Aug 21, 2007 10:39 AM
surfingsk8r
Aug 1, 2006 05:13 AM
slo4door
May 5, 2006 04:58 PM
