Vtec Solinoid oil pressure switch
I am about to start up my new build however this is the first time I have done a swap into a non vtec chasis. I have installed a built LS vtec in my 96 EK hatch. I dont see that my wire harness has a vtec solinoid oil pressure switch plug. is it required to use the oil pressure switch on the v tec solinoid or not. If not I will just run the one wire for v tec from the ecu if it is required I will need to find the 2 wire plug for it.
Bimmerman
Jun 15, 2005 05:23 PM
