made a welding table
Old Oct 27, 2010 | 07:27 PM
russianvr4's Avatar
OG Fabricator
Default made a welding table
always wanted to build something dedicated to welding/fab. just went and picked up about 400lbs worth of steel and went at it.
here are the results:
4x6' sheet of 5/16" hot rolled steel on 2x2 14g box tubing and 3.25" casters
when you're not strong enough to lift something this size/weight call your brain for help :D
its not 100% finished yet, going to tie in the legs tomorrow when i buy some more box tubing and brace it.
Old Oct 27, 2010 | 07:52 PM
SD_Lurker's Avatar
HT White Ops
Default Re: made a welding table
That's not a very sturdy design.. I'd add some material connecting at least the 2 rear legs together.. What you should do is weld a piece connecting the legs together.. Kinda hard to explain but it would be very simple to do. Pick a side of the table to call the front so you can kinda offset the cross bars allowing you to still have some leg room. Then throw a thin sheet down and tack it and wallah, you have a lower shelf.
Old Oct 27, 2010 | 08:01 PM
russianvr4's Avatar
OG Fabricator
Old Oct 27, 2010 | 08:37 PM
madblkscientist's Avatar
i like it
Old Oct 28, 2010 | 12:28 AM
drift2004's Avatar
Some people just can't read
Old Oct 28, 2010 | 03:30 AM
SD_Lurker's Avatar
HT White Ops
haha I double checked to see if you had said anything like that.. However, I didn't read the bottom part at all.. LOL right on..
Drift, lick long and like it..
Old Oct 28, 2010 | 08:25 AM
DESTROYER's Avatar
lick long? lol
Old Oct 28, 2010 | 05:17 PM
E-Rok's Avatar
EPIC TUNING
I would have left a couple inches all around as overhang, but thats just me.
Old Oct 28, 2010 | 05:56 PM
russianvr4's Avatar
OG Fabricator
i have overhang on the back side just in case, other sides are flush because i hate sharp corners.
Old Oct 28, 2010 | 05:59 PM
javierb14's Avatar
what kind of casters are you using? i have seen some heavy welding tables "flat spot" casters after sitting for a while.
Old Oct 28, 2010 | 06:03 PM
russianvr4's Avatar
OG Fabricator
just some cheapies i picked up for 3 bucks a piece. if they go out replacing them will be piece of cake so im not worried.
Old Oct 28, 2010 | 08:04 PM
drift2004's Avatar
The proper answer of an un-educated person
Old Oct 29, 2010 | 05:08 AM
tepid1's Avatar
If you do ever get new casters use wheel locks. I'd hate to see that thing get away from someone while trying to move it. lol
What's it weigh.... rough estimate?
Old Oct 29, 2010 | 06:41 AM
drift2004's Avatar
How much it cost in materials?
Old Oct 29, 2010 | 08:06 AM
russianvr4's Avatar
OG Fabricator
about 400 lbs for the sheet/tubing.
the sheet i got a t drop price for 45 cents/lb tubing was 1.30/ft i think
all in all it was 250 bucks with casters and i also got aluminum and SS hanger rod 12ft each
not too bad.
Old Oct 29, 2010 | 10:35 AM
SD_Lurker's Avatar
HT White Ops
Right, last I checked I have a master in Mechanical Engineering..
Old Oct 29, 2010 | 12:55 PM
drift2004's Avatar
you must have failed communications
Old Oct 29, 2010 | 01:03 PM
russianvr4's Avatar
OG Fabricator
girls, settle down please!
Old Oct 29, 2010 | 01:50 PM
CRMB's Avatar
OG Fabricator
Eugene, put a brace down the middle length wise just under the table top too. We ruined a *thicker* table top a couple weeks back hot forming (aka beating the hell out of something with heat) that could have easily been prevented if we had properly braced it under the table surface.
Old Oct 29, 2010 | 02:41 PM
drift2004's Avatar
hey how much are the wheels rated for? how much weight?
Old Oct 29, 2010 | 03:54 PM
Danked's Avatar
I think it looks great. Good job!
Old Oct 30, 2010 | 09:49 AM
russianvr4's Avatar
OG Fabricator
thats in the plans for sure, soon as i pick up some more square tubing.
i have no idea how much the wheels are rated for.
G3NR8
May 25, 2007 02:13 PM
DAinfamousR
Jan 30, 2007 06:49 AM
1Quikgsr
May 13, 2006 03:30 PM
b16_madman
Jan 30, 2005 01:10 PM
dc24me
Audio / Security / Video
23
Jun 29, 2004 06:44 PM
