how important to resize rod when installing arp rod bolts?
Old Sep 20, 2002 | 03:03 PM
FastFoot's Avatar
Default how important to resize rod when installing arp rod bolts?
i installed some new arp bolts on my ls bottom end..i just torqued it down to the required torque spec. directions says it recommends that we resize the rod. i didnt...how important is this step? u guys think id be ok? thanx
Old Sep 20, 2002 | 03:45 PM
Jared's Avatar
Default Re: how important to resize rod when installing arp rod bolts? (FastFoot)
I don't see any point in resizing the rod unless it was out of round, and if it was you'd be hearing things to begin with.
Old Sep 20, 2002 | 10:19 PM
earl's Avatar
Default Re: how important to resize rod when installing arp rod bolts? (Jared)
Sometimes when you press the new bolt in, it distorts the big end and you have to resize. Need to check roundness after installing the new bolt.
Old Sep 27, 2002 | 08:16 PM
00civicvtec's Avatar
Default Re: how important to resize rod when installing arp rod bolts? (earl)
I guarentee you that the ARP rod bolts distorted your rods. If you are going to take the time to build a motor, do it right. Take them to the machine shop and get the resized....my LS rods were all out of round when I got ARP rod bolts installed, but all it takes is a little machine work.
Old Sep 28, 2002 | 12:09 AM
C-speed's Avatar
Default Re: how important to resize rod when installing arp rod bolts? (00civicvtec)
Yup.. we resize everytime the rod bolts are upgraded.. not worth it to save a few bucks when you are at that stage.
p3t3rxp4n
33
Feb 4, 2015 08:41 PM
rich7777
Mar 1, 2010 07:43 AM
GSR615
Jan 23, 2009 11:13 AM
Wazup
Mar 31, 2005 02:58 PM
untitled
Jul 2, 2003 11:25 PM
