GSR piston valve relief height
Old Oct 26, 2010 | 05:43 PM
Spawne32's Avatar
Default GSR piston valve relief height
I want to run GSR 10.2:1 compression pistons on an LS block with LS rods and crank, however I also want to run high lift cams. Based on the calculations the B18B block has a lower deck height then the B18C1 block, how will this affect the maximum lift cam that can be used on factory GSR pistons, and does anyone know what the maximum lift cam that can be used on GSR pistons is?
sleepencivic
Oct 21, 2010 08:57 AM
Toy Civic
Jan 9, 2007 08:22 PM
ORANGE EF
Apr 20, 2006 10:58 PM
NightmareApex
22
Dec 18, 2004 10:53 PM
RAWB
Mar 23, 2003 03:51 PM
