Where to send block for Machining/Assembly?
Old Oct 26, 2010 | 06:13 AM
kte324's Avatar
Default Where to send block for Machining/Assembly?
I recently bought semi-built B16. The engine had all new parts (eagle rods/srp/acl bearings). It started knocking so I pulled it out and took it apart. The engine had less than 200 miles. I don't have a problem rebuilding an engine, but when it comes to something that will be seeing 9K rpm, I'd rather let the professionals handle it. What are some good shops that I can send this to get fix, balanced, and assembled?
The rod bearings looked alright except one that was alot darker than the other ones. Will post pics later.
Old Oct 26, 2010 | 06:23 AM
The Show Stopper's Avatar
Default Re: Where to send block for Machining/Assembly?
TPR Racing Engines
2720 Symmes Road
Fairfield, Ohio
45014
513.942.7020
Thanks,
Rob-
Old Oct 26, 2010 | 06:33 AM
Garcia-Racing's Avatar
Laskey Racing Engines
Old Oct 26, 2010 | 07:09 AM
CDecker0218's Avatar
Old Oct 26, 2010 | 07:40 AM
Ls_dx's Avatar
Who assembled the motor? Did they check oil clearences? Did you break it in?
Old Oct 26, 2010 | 11:34 AM
kte324's Avatar
Yeah, they built the motor that's in my sig. It still has a lot more in it. I think that's where I am going.
I don't know who assembled it, but it seems that they did not check the clearences. I know that the acl race bearings run a little loose and that seems to be the case. I was in the process of breaking it in, never got on it.
Old Oct 26, 2010 | 01:23 PM
dragallmotor24's Avatar
RS Machines or Golden Eagle...
Old Oct 26, 2010 | 01:46 PM
ninesecrx's Avatar
Thanks for the bump fellas! Here is our contact info if you need us
Laskey racing
2860 E. Gretta lane, Suite H
Anaheim, CA 92806
714-688-0222 if you wanted to chat on the phone
or
laskeyracing@gmail.com if you prefer to talk through email.
Old Oct 26, 2010 | 01:53 PM
mrbsponge's Avatar
Originally Posted by ninesecrx
Thanks for the bump fellas! Here is out contact info if you need us
Laskey racing
Anaheim, CA 92806
or
Laskey is the place to go! They have done all my sleeving as well as for my shop. They do some amazing work.
Old Oct 26, 2010 | 06:41 PM
kte324's Avatar
Laskey racing
Anaheim, CA 92806
or
sent you a message.
Old Oct 26, 2010 | 08:26 PM
MrParks's Avatar
we have had great sucess with darton mid and rs machine to do the machine work. best work ive seen so far.
Old Oct 26, 2010 | 08:47 PM
you speak french?
Old Oct 26, 2010 | 11:51 PM
rs250nut's Avatar
Laskey racing all the way, customer service is the best I've had even beating shops this side of the pond. Would never use anyone else.
Old Oct 27, 2010 | 06:25 AM
DC2_117's Avatar
To Laskey Racing Engines heard nothing but good things about them.
I personally use ERL Performance. Awesome customer service and great turn around times.
Old Oct 27, 2010 | 08:07 AM
bosted coupe's Avatar
LDL sped shop i'n vegas
Old Oct 27, 2010 | 05:53 PM
kte324's Avatar
Yeah, I had my last sleeved engine built by Laskey. I was just seeing who else is out there and getting some opinions/ideas.
I will be shipping this thing out Monday to Mike.
Old Oct 28, 2010 | 03:57 AM
rschoener's Avatar
Inlinepro.
Old Oct 28, 2010 | 04:14 AM
MARC P's Avatar
^X2
Allen Built ftw
Marc P
Old Oct 28, 2010 | 08:38 AM
PuroMotor's Avatar
Allen Built all day long
turbotypeR@SPEC
Dec 5, 2009 05:20 AM
Bond
53
May 11, 2009 05:26 PM
Bond
May 6, 2009 09:57 PM
wm5holla
Jul 28, 2003 02:06 PM
xXsarcasmXx
Feb 28, 2002 08:42 PM
