need some advice with motor building...
Old Sep 20, 2002 | 12:06 PM
xJ.SLOTHx's Avatar
Default need some advice with motor building...
ok im finally starting on my motor work.... (after all this time) well, as of right now i have a B16 in my hatch & i have a complete GSR block ready to get built. im looking to build a serious n/a strip/street motor and this is what i have divised so far for the block...check it out and give me your opinions an thoughts and if so help me critique my ideas. thanks.
B18C1 block
resleeved 85mm bore
LS crank ( 89mm stroke opposed to 87.2mm )
Eagle Rods
Forged pistons (dont know what brand yet)
new bearings, vtec oil/water pumps
Old Sep 20, 2002 | 12:15 PM
X2BOARD's Avatar
Default Re: need some advice with motor building... (ian)
Get everything balanced and inquire about chamfering the oil holes on the crank.
What piston r u gonna use (CR) ? That's a good starting point w/ the GSR block/LS crank.
X2
Old Sep 20, 2002 | 12:19 PM
xJ.SLOTHx's Avatar
desired CR will be 11.5:1, gotta love that california 91octane
Old Sep 20, 2002 | 12:21 PM
X2BOARD's Avatar
Heh heh... in Fl and happy... sunshine, no emissions testing and quality 93 juice.
Old Sep 20, 2002 | 12:45 PM
acura_typer's Avatar
Banned
My suggestions would be:
Keep the GSR crank
Go with Endyn RollerWave pistons (he has that compression you want in 85mm)
Eagle rods
I just built a B20/VTEC, so I'm pretty familar with all this good stuff.
Old Sep 20, 2002 | 01:14 PM
xJ.SLOTHx's Avatar
Default Re: need some advice with motor building... (acura_typer)
Keep the GSR crank
Eagle rods
could you give me some reasoning why i should keep the GSR crank in there instead of the LS? ... what are the specs of your B20VTEC and any dyno readouts?
Old Sep 20, 2002 | 06:08 PM
b19coupe's Avatar
Default Re: need some advice with motor building... (C5_ALLMOTOR)
Another reason to keep the GSR crank is the rod/stroke ratio. The better R/S ratio of the GSR takes more kindly to high rpm's, important when building an N/A motor.
Old Sep 20, 2002 | 08:36 PM
onebadLSS's Avatar
I agree, keep the GSR crank. You'll be much happier with the revs (not to mention life) that the shorter stroke will give you. This is why I'm building my new LS with a B16 crank and rods. The last race engine didnt like holding together at 9900 consistantly.
Old Sep 20, 2002 | 08:53 PM
xJ.SLOTHx's Avatar
Default Re: need some advice with motor building... (onebadLSS)
aiight coo..thanks guys
Old Sep 21, 2002 | 01:51 AM
S13 slide's Avatar
what would you get if you use the gsr crank in a ls?
Old Sep 21, 2002 | 06:43 AM
TimoneX's Avatar
New User
Default Re: need some advice with motor building... (S13 slide)
Well first, send me the sleeves. I gotta "test" them out for you...
Seriously though I'd use the GSR crank and go with the Endyn rollerwaves as someone suggested. They're very well designed and you should be able to get away with more compression than you otherwise would. Sounds good to me, let us know how all this comes out.
Old Sep 22, 2002 | 09:33 PM
ITRbroham's Avatar
shit post warrior
87.2MM stroke and 1797cc.
GSR615
12
Aug 19, 2011 11:14 AM
JohnData
May 25, 2010 07:38 AM
b18bc3po
17
Oct 8, 2009 07:28 AM
kevs-ej1
Nov 28, 2005 06:20 AM
99lsvtecauto
Jan 3, 2005 04:35 AM
