abs delete?
Master cylinder, brake booster, 2 lines from master to prop valve, and prop valve from 98+RS will be a direct bolt in. Or, get prop valve from 98+ integra RS and 2 custom lines from your current master cylinder to prop valve.
whats so special about a 98+ RS prop valve?
The 94-97 and 98-01 RS integras came factory without abs. The prop valves are different between the two. Get the right prop valve and the rear brake lines will bolt in to the prop valve. Nothing special just the outside dimensions of the unit.
malubawla
20
Apr 9, 2007 04:28 PM
