99'B20B timing degree?
Old Oct 21, 2010 | 05:33 PM
98bucket's Avatar
Default :edit: what ecu should i use for my 99'b20b? in a 90'integra?
???? im gonna buy a conversion harness to obd1...what ecu should i run?
Old Oct 21, 2010 | 05:38 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 99'B20B timing degree?
what degree? I'm not sure what you mean. You have to zero the whole engine, cam's and crank and then install the belt to make sure everything is lined up. If you're not sure how to do this, get a manual or look it up online.
Old Oct 21, 2010 | 05:50 PM
98bucket's Avatar
how do i know if the timing is off? the belts on, i just put the motor in, but its not runnuing right...
Old Oct 21, 2010 | 06:37 PM
00Red_SiR's Avatar
All Motor Mentor
If everything is lined up and the belt is tight and properly adjusted, your problem isn't there. Is the ignition timing correct? is the motor stock or modified? if modified, is it tuned? Do you know how to check these things?
Old Oct 21, 2010 | 06:45 PM
98bucket's Avatar
ok yeah the timing was right....its not modified.... i running the 99'B20b on a stock obd0 pr4 ecu.... isnt it supposed to be running right? im thinking of converting to obd1 with the jumper harness but what ecu should i run? i just want a good/reliable motor....
Old Oct 21, 2010 | 07:08 PM
00Red_SiR's Avatar
All Motor Mentor
What distributor are you running? Jdm engine I assume? What car is it in now?
Old Oct 21, 2010 | 07:11 PM
98bucket's Avatar
im running the stock obd0 distributor. my car is a 90'integra ls (pr4ecu). its a jdm engine...
Old Oct 22, 2010 | 01:09 PM
00Red_SiR's Avatar
All Motor Mentor
maybe try the hybrid/tuning section to see what they say about ecu to use etc.
Old Oct 22, 2010 | 01:32 PM
98bucket's Avatar
ok thanks man.
Mickle
Sep 4, 2017 07:34 AM
LeegodaEG
May 6, 2013 08:33 PM
See Are X
May 26, 2006 08:09 PM
90jdmcrxdude
May 14, 2006 04:36 PM
LostCRX
Jul 9, 2004 03:55 AM
