Ecu's keep buring up in the same spot..
Old Oct 20, 2010 | 06:04 PM
GSR_hatch936's Avatar
Default Ecu's keep buring up in the same spot..
Ok I have a Gsr swap built in a Eg Si shell with a wire tuck, with that said I have put two different ecu's and they got burnt in the same spot. Any help would be good! Heres pics of where the ecu is buring up at.
Old Oct 20, 2010 | 06:12 PM
Dontoh's Avatar
Default Re: Ecu's keep buring up in the same spot..
odd, never heard of it before. in for answers
Old Oct 20, 2010 | 06:29 PM
Former User's Avatar
Check whether any sensor connectors are swapped, such as the IAT and EVAP purge:
https://honda-tech.com/forums/showpo...81&postcount=4
Old Oct 20, 2010 | 07:09 PM
Ok I'll switch them around. Also is the ecu useable and or be fixed?.
Old Oct 20, 2010 | 07:40 PM
BluE-EK's Avatar
the ecu can be fixed, but you need to check in the electronic diagram or in other ecu the damaged component, and re-solder the lines damaged is no big deal if you know about electronics
i can help you but I am in Monterrey Mexico
$MIKE$
Feb 28, 2014 01:24 PM
1988EFHB
Mar 26, 2010 06:50 PM
shytdoode
May 20, 2009 03:41 PM
jaha-crx
Sep 24, 2008 09:37 AM
tuanpn21
Dec 26, 2006 01:54 PM
