Honda S2000 Honda S2000
Can shift gears at a stop with out pressing the clutch & car does not move.
Old Oct 20, 2010 | 08:32 AM
skater5067's Avatar
Icon2 Can shift gears at a stop with out pressing the clutch & car does not move.
I own a 2001 s2000. And I noticed it getting hard to shift so I checked the clutch fluid and it was low. I put some clutch fluid in that has already been open ( I know not that good but it was what I had). When I put it in I put in too much not knowing. I pumped the clutch with out the cap on like 10 times. When I went to put the cap on I noticed it was over filled. I took out enough to be at the max line. I then pushed the clutch petal down and put it in gear and let go and the car did not move. I tried other gears still nothing. I then tried shifting with out using the clutch petal and I could easy with no grinding at all.
What do you think could be the problem? Sorry it is kinda long but I wanted to give as many details as I could about the problem.
Any help would be great. I was thinking that the slave cylinder may of been stuck fully depressed and is not letting the clutch go. But I couldn't find that every happing to anyone else.
Old Oct 20, 2010 | 08:53 AM
skater5067's Avatar
I own a 2001 s2000. (I know it is not the right section but I figured the prob would be the same for any model) And I noticed it getting hard to shift so I checked the clutch fluid and it was low. I put some clutch fluid in that has already been open ( I know not that good but it was what I had). When I put it in I put in too much not knowing. I pumped the clutch with out the cap on like 10 times. When I went to put the cap on I noticed it was over filled. I took out enough to be at the max line. I then pushed the clutch petal down and put it in gear and let go and the car did not move. I tried other gears still nothing. I then tried shifting with out using the clutch petal and I could easy with no grinding at all.
Old Oct 20, 2010 | 09:34 AM
delsolo95's Avatar
Default Re: Can shift gears at a stop with out pressing the clutch & car does not move.
Since you were low on fluid, air might of entered the lines. I suggest you bleed the clutch! Do it a couple of times
Old Oct 20, 2010 | 09:37 AM
omg_miiiike's Avatar
Did you bleed the lines?
Does the clutch pedal have resistance or does it go straight to the floor?
Did you check under your dash for any leaks in the clutch master cylinder?
Have you changed the transmission fluid?
Old Oct 20, 2010 | 09:59 AM
skater5067's Avatar
yea i am about to try that now but if i put in in gear i can still push the car around with the motor off like it was in neutral still.
Old Oct 20, 2010 | 10:19 AM
camoy's Avatar
you will need to check under the car on the drivers side you will see the clutch slave cylinder you can pull the black boot back. This boot covers the slave cylinder piston and the clutch fork, you need to check to see if the piston is stuck out or the fork is stuck. It sounds like something happened when you pumped the clutch and now either the slave cylinder piston is stuck out or the clutch fork is stuck. Making it not engage the pressure plate, this will cause what you describe as being able to push the car around in gear.
Another thing could be your clutch is so past worn that it no loger clamps even with it engaged and in gear. Before you had this new problem and it was hard to shift did you have issues with the clutch slipping?
Old Oct 20, 2010 | 10:24 AM
skater5067's Avatar
yea it moves when you push it but not very far. i am going to bleed the system right now and see what happens. and when the car was running it wasn't slipping at all grabbed pretty hard the last owner said he changed the clutch
Old Oct 20, 2010 | 11:03 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
the last owner can say a lot of things... did he show documentation???
Old Oct 20, 2010 | 11:29 AM
skater5067's Avatar
i just bled the system and i took the boot off i can see it getting pressed in and out and the fork is moving but still nothing. could it be anything else
Old Oct 20, 2010 | 11:30 AM
skater5067's Avatar
no he dident but the clutch was not slipping at all and this happened right after i filled up the clutch fluid. it was working fine last night and i left it over night filled up the fluid and tried to drive and got nothing.
and i am pretty sure there is no air in the line because the fluid was very black and i used super blue fluid and it was coming out bright blue thru the bleeder with no bubbles at all.
Old Oct 20, 2010 | 11:37 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The clutch fluid is not for the engagement of the clutch. It's for the disengagement. So nothing you did with the fluid reservior (over or under filling, filling with grape jelly, emptying out, whatever) would not affect the ENGAGEMENT of the clutch.
Your disk is probably worn out. Maybe time for a new clutch.
Old Oct 20, 2010 | 11:40 AM
skater5067's Avatar
Yea but if i can shift thru all the gears with the car turned on and i do not have any grinds and the car doesn't move doesn't that mean the clutch is always disengaged?
Old Oct 20, 2010 | 12:01 PM
ReddotsS2K's Avatar
So your saying that if the car is running, in gear, and the clutch is not pressed the car still acts like its in nuetral? so the clutch is not engaging at all, correct?
Old Oct 20, 2010 | 12:03 PM
skater5067's Avatar
yes car is on motor running and i can shift gears without pushing the clutch pedal with no grinding and the car does not move.
Old Oct 20, 2010 | 12:25 PM
Driven's Avatar
just because you can shift without the clutch doesn't mean anything, since you can shift without the clutch in any gear with a perfectly good gearbox (except from a stop and the engine running).
what were you doing prior to the car becoming harder to shift? did it just progressively go away and you added fluid... or were you driving it hard?
Old Oct 20, 2010 | 12:30 PM
skater5067's Avatar
no i can shift the car without pressing the clutch with the motor on. with no grinding. and when i put it in gear it still does not move. it was working fine last night the only thing i did was put clutch fluid in the car. and it was not hard to shift before this happened. just was low on clutch fluid
Old Oct 20, 2010 | 12:31 PM
ReddotsS2K's Avatar
Very weird. Sounds like there is an issue somewhere with the pressure plate. It should be pushing the clutch to the flywheel but it sounds like it is failing to. If it were the slave cylinder or fork then it would disengage the clutch, but the clutch is already disengaged somehow. Unfortunatly this does not sound like a quick and easy fix. Pulling the transmission on this car is a pita.
Old Oct 20, 2010 | 12:39 PM
skater5067's Avatar
Yea that is what i was thinking but it is so weird that it just stopped working over night. I am hoping it is something else but that is was it sounds like to me. a new clutch any other ideas?
Old Oct 20, 2010 | 12:41 PM
Black S2K's Avatar
ur master cylinder could have gone to **** look at in from the inside C if its leaking the seals could be bad enough for it not to work at all but the peddle will still feel like its ok
Old Oct 20, 2010 | 12:44 PM
skater5067's Avatar
i did look there there was some old thick fluid on the seal but i did not see anything fresh coming out when i pressed the clutch in.
Old Oct 20, 2010 | 12:46 PM
ReddotsS2K's Avatar
I hope for your sake it is something else but the only other thing i can think of is your transmission. With the car off does is sound and feel like its going into gear?
Old Oct 20, 2010 | 12:50 PM
skater5067's Avatar
yea you can hear it and it feels like it is going into gears just fine. with the car on or off. but before this happened i use to hear a slight noise when the clutch was not pushed it like a bearing noise. and when i pushed the clutch in it would go away. but now today i dont hear that bearing noise so it does also seem like the clutch is just pushed in all the time guess i should just get a new clutch or take it to the shop hope i can get some other options if there is any
Old Oct 20, 2010 | 12:56 PM
ReddotsS2K's Avatar
I don't have anymore ideas. sounds like a pressure plate/clutch issue. Let us know when you figure out what the problem is. Make sure you get everything...flywheel, clutch, pressure plate, throw out bearing, etc.
Old Oct 20, 2010 | 12:59 PM
skater5067's Avatar
Will do
Old Oct 20, 2010 | 01:33 PM
https://honda-tech.com/forums/showthread.php?t=2851629
Pick a thread.
