What clutch best for my 94 Del Sol VTEC B16A3 (with plans to boost)?
Old Oct 19, 2010 | 11:25 PM
PhillyDelSol's Avatar
Default What clutch best for my 94 Del Sol VTEC B16A3 (with plans to boost)?
I have a 94 VTEC with a cold air intake, everything else stock. I'm rebuilding the motor OEM and then I'm going to boost it. I want to get a performance clutch but I'm not sure how far to go with it. I'm thinking a stage 2 will probably do it but I'm wondering if I should go with a stage 3 just in case. It's primarily a street/daily driving car but I'm going to take it to the track once I boost it.
Old Oct 19, 2010 | 11:31 PM
Hondarookie93's Avatar
Default Re: Need advice on what stage clutch for my Del Sol
well i thought we had the same motor bcuz i have a 96 dx with a d16y7 <-- lol but anyway ive got a stage 2 clutch nd i barely touch the clutch to shift but thats just my input lol plus ive never driven with a stage 3 :/ but i do love my stage 2 tho!!!!
Old Oct 20, 2010 | 12:49 AM
I just realized I forgot to put that info on there. 94 Del Sol VTEC B16A3. Thanks
Old Oct 20, 2010 | 10:04 PM
no problem yo
Old Oct 21, 2010 | 01:49 PM
matt9112's Avatar
a stage 1 is all you need.....but stage 1-3 share the same pressure plates by most company's so if you want to over clutch go ahead...
i have a 96 civic with a stage 1 and a light flywheel and some shifter work and its fine.. grabs hard as hell and kick the sh*t out of the 109 hp engine...
Old Oct 21, 2010 | 01:56 PM
93egSLEEPER's Avatar
How much power do you plan on making? This will allow you to pick the right clutch/pressure plate setup.
Old Oct 22, 2010 | 04:54 AM
I'm new to this so I'm not exactly sure. I'm estimating in the 250-325 range depending on what kind of turbo I put on it. I'm getting a lightened flywheel too.
Old Oct 22, 2010 | 05:02 AM
[ej]Jonathan's Avatar
Lord of the idiots
my brother has a stage 1 in his sol. it feels very nice.
when i bought my si, the previous owner wasnt sure of what stage clutch was in it, i think its 2, cause it feels stiffer than my brothers. so i would go stage 2
Old Oct 22, 2010 | 05:14 AM
Libertariat's Avatar
Ek Forever y0!
I hate it when people refer to clutches universally as "stage 1 or stage 3"
Every company has different clutches and different marketing. Just saying "stage 2" is a terrible idea as it really matters which clutch manufacturer you're talking about.
Old Oct 22, 2010 | 05:29 AM
Ok.. well how do I measure what kind of clutch I need. I've heard that HP is not a good measurement. Is it tourque that you need to know about? Like I said I'm new to this
Old Oct 22, 2010 | 06:27 AM
Ek Forever y0!
Default Re: What clutch best for my 94 Del Sol VTEC B16A3 (with plans to boost)?
for mild turbo builds I've seen many people run an OEM clutch. There's no problem with that whatsoever.
For more serious builds 250+whp you might want to get something a little more substantial. There's no need to go overkill on your clutch.
WHP is actually a pretty good rule of thumb. If you're planning a mild turbo build I would get something a little stiffer than stock.
To reiterate, some "Stage 1" is an OEM replacement with some companies, other companies their Stage 1 is not an OEM replacement, it might be similar to someone elses stage 2 or stage 3.
Old Oct 22, 2010 | 12:02 PM
matt9112's Avatar
sorry forgot to mention that clutchmasters makes my stage 1 and it is an upgraded pressure plate and clutch plate. and it plenty.
Old Oct 22, 2010 | 12:05 PM
fv8s's Avatar
i highly recomend using a Competetion Clutch. I have a Stage 5 unsprung 4 puck in my car and it holds its own. A competition stage 2 will be fine. Anything else will be overkill for your power goals.
schpiel
Apr 28, 2007 01:31 PM
Blue_Si
25
Aug 4, 2003 04:04 AM
Buckkaaaa!!
Jun 12, 2002 02:50 AM
