A lot of Engine Movement??
Okay so I have a 99 gsr with about 195k miles. I already changed out the the lower mounts, and the rear mounts with OEM mounts with ES polyurethane inserts because they were torn.
My question is, how come I'm still getting as much engine movement as before? Would changing out the top two mounts solve my problem? Thanks.
yes that would help. i would have replaced them before those lower mounts. you have 3 main mounts and if you replaced 1 and you are still having the problem then its the other 2. you can look at the mounts and see if they are bad. just how much movement are we talking anyways?
Are you driving the car while looking at engine movement?? huh? I am guessing the car begins to jerk. I think you did already, but all of your mounts are replaced?
I replaced the bottom two, and the rear mount. I looked at the top mounts today, and they looked okay (as in I didnt see any cracks). Do they just go bad over time? I do have almost 200k on my car now.
EG6Boy702
33
Apr 27, 2009 03:55 PM
vtecmike1
Nov 19, 2003 07:19 AM
