head bolt tourqe spec.
Old Sep 20, 2002 | 07:05 AM
kongzilla's Avatar
Default head bolt tourqe spec.
any one know what spec it is for a B18b. i really need to find this out. thanks.
Old Sep 21, 2002 | 08:39 AM
TimoneX's Avatar
New User
Default Re: head bolt tourqe spec. (kongzilla)
It's 60 lbf/ft for the C1. I am unsure wether or not it's different for the killer Bs. If you don't have one I strongly recomend a Helms service manual.
http://www.helminc.com/
Old Sep 21, 2002 | 03:08 PM
ginsu1797's Avatar
The b18b1 is 63 ftlbs. You really need a factory manual from Helm (not freaking haynes!!!), it's worth every penny.
Old Sep 21, 2002 | 04:00 PM
Michael Delaney's Avatar
it's a 2 stage torque down: 22 lb ft in the sequence specified by the honda instructions followed by 61 lb ft in the same sequence. the head bolts and washers should be oiled with engine oil ahead of time. If you are using ARP head studs then use ARP torque down specs and their lubricant provided with their studs.the decks should be clean, use a new head gasket,cam gear pulleys with their upmarks pointed up, align the oil control orifice and dowel pins...a helms manual is your friend so you don't guess or listen to other people... honda's specs only.
[Modified by Michael Delaney, 8:01 PM 9/21/2002]
Old Sep 21, 2002 | 07:17 PM
kongzilla's Avatar
Default Re: head bolt tourqe spec. (Michael Delaney)
thanks guys.
F!ip
21
Jan 28, 2011 04:58 PM
KaYsLaY
Jun 21, 2008 09:50 AM
killafred187
Jan 30, 2008 04:31 PM
jspresso
Aug 19, 2004 12:53 PM
k-smit35
Aug 1, 2004 05:01 PM
