What rad hoses for 92 cx with b18b?
Old Sep 20, 2002 | 06:12 AM
DOHCarp's Avatar
Default What rad hoses for 92 cx with b18b?
im just about finished with the swap and Im not sure which hoses I should be using since the stock cx ones are to small and don't seem to line up correctly.
also do I need an entirely new accelerator cable or just the mount for the intake manifold. thanks!!
Chad
Old Sep 20, 2002 | 08:20 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: What rad hoses for 92 cx with b18b? (DOHCarp)
You should use 99-00 Civic SI upper and lower radiator hoses, or also the older Del Sol DOHC VTEC hoses will work also, i highly recomend you change the radiator also while yer at it....As for the throttle cable,u may modify a bracket to fit. other then that, there fairly cheap at honda, good luck..
WhiteOnRice
13
Oct 28, 2007 06:57 PM
prjctwhteg
Nov 10, 2006 11:46 AM
Mike_C
11
Oct 24, 2003 04:12 PM
B_CRUZ!
13
May 22, 2002 02:17 PM
