Vtec, is it speed sensative?
Old Sep 20, 2002 | 05:28 AM
90_Civic_Hatch's Avatar
Default Vtec, is it speed sensative?
Is Vtec speed sensative on my B16a? I 've been trying to figure out why i dont have vtec and it hit me that it might be speed sensative. I dont have my speedometer cable hooked up. could this be my problem??
thanks
Old Sep 20, 2002 | 05:30 AM
SuperCivic's Avatar
Default Re: Vtec, is it speed sensative? (90_Civic_Hatch)
yes, you have to be moving. i'm surprised you're not getting the VSS code.
AussieK24's Avatar
Yes it needs an input from a VSS ( Vehicle Speed Sensor) for VTEC to engage
Old Sep 20, 2002 | 05:34 AM
slowman's Avatar
I took way too long
Default Re: Vtec, is it speed sensative? (b16a4me)
I thought it was RPM activated?
Old Sep 20, 2002 | 05:45 AM
SuperCivic's Avatar
Default Re: Vtec, is it speed sensative? (slowman EF)
you need
1. rpm activation point
2. correct oil pressure
3. correct temperature
4. input of speed from VSS (20mph i think)
Old Sep 20, 2002 | 06:00 AM
Default Re: Vtec, is it speed sensative? (SuperCivic)
good deal, looks like i found my problem. At first i thought it was only oil pressure and rpm. I am throwing code 17 (speedo cable code). I guess i know what I'm going to be doing today. Hooking that cable up!
thanks
Old Sep 20, 2002 | 07:08 PM
crxjdmsir's Avatar
It is 20 Mph for VTEC engagement. Also if your ECU throws any codes your computer will go into "limp mode". When in this mode your rev limiter will kick earlier and you will lose VTEC activation till the codes are lost. The same will happen untill vehicle reaches normal operating temp.Warm up period
aragorn1023
Aug 12, 2007 11:11 PM
LudeJdm
Oct 8, 2006 03:02 PM
JDM_SOHC
Nov 8, 2005 08:20 AM
iridebiketrials
Aug 20, 2004 02:24 AM
blykins
Oct 30, 2001 10:50 PM
