Transmission & Drivetrain Gearboxes, Differentials, Clutches
Using GM syncromesh to stop 3rd gear grinding???
Old Oct 17, 2010 | 08:44 PM
the_branster's Avatar
Icon2 Using GM syncromesh to stop 3rd gear grinding???
Pretty much tried everything from new clutch, to slave, master cylinder, and new trans oil and 3rd gear still grinds at 3.5k rpm and up. Heard some great stuff about GM syncromesh modified and I'd rather try that than a full trans rebuild. Does it work right away? Does it really stop grinding? Feedback will be very much appreciated.
Old Oct 17, 2010 | 09:32 PM
bosted coupe's Avatar
Default Re: Using GM syncromesh to stop 3rd gear grinding???
Just fix ur tranny it's fairly cheap the gm stuff cost like 10 to 15 a bottle
Spend 100 bucks and fix ur tranny verry easy to fix
Old Oct 17, 2010 | 10:17 PM
Jimmy's Avatar
Global Moderator
In your situation GM Synchromesh would be a temporary band-aid. It's good stuff though, I've been using it for years in my b16 tranny, gsr, now lsd gsr tranny.
I actually have been using pennzoil synchromesh lately, which can be found cheap at your local auto zone.
Try searching.
Old Oct 17, 2010 | 10:47 PM
what do i rebuild? Should I just buy a synchro kit?
Old Oct 17, 2010 | 10:51 PM
It's and lsd b16 hydro trans, never grinded with previous owner (I know this because he's my friend and I got to race his car before with no grinds). All of a sudden, in my car, it grinds first thing going down the street? Could it be the linkage in my car?
Old Oct 18, 2010 | 07:31 AM
TheCrimsonGhost666's Avatar
I use the pennzoil synchromesh, alot cheaper and as far as I know is the same thing. I put it in my tranny for a 3rd gear grind at high rpm, within 2 weeks the grind was eliminated completely, this stuff is great for 6 bucks!!
Old Oct 20, 2010 | 12:03 AM
Crimsonghost666, did it still grind withing the two weeks? And how bad was your trans before you put the new fluids? Mines grinded at about 3-3.5k rpm. I put in the syncromesh today and it goes all the way up to 4.5k rpm without grinding. I'm hoping it'll get better in the next couple weeks.
Old Oct 20, 2010 | 02:21 PM
aleXander79764's Avatar
Ive heard that the pennzoil synchromesh is good stuff and cheap.
This is alittle of topic but Ive gota know.
I just bought a 94 Civic w/b16
It needs axles so are the 94-00 tegs gonna work??
Old Oct 20, 2010 | 02:30 PM
With my experience it took a couple weeks to take full effect, but I dont drive that much, the more you drive the quicker it will take full effect. My grind was only at higher rpms, but it was pretty consistent, 2 weeks after putting the synchromesh in it was gone completely, and hasnt come back yet.
Old Oct 20, 2010 | 03:14 PM
Aquafina's Avatar
It is a band-aid. To fix the problem it will likely take a sleeve assembly.
Honda MTF, GM Synchromesh, and Pennzoil Synchromesh aren't good fluids to use unless you drive the car like a grandma and have no power. They're 5w-30 and 10w-30 needs to be used.
Old Oct 22, 2010 | 08:10 AM
94jdmeg6civic's Avatar
im using torco mtf and i have the same problem up high like 7k plus going into 3rd
bigboom
Apr 12, 2010 10:34 PM
teg_95
10
Mar 30, 2009 06:19 PM
swappedcx
Oct 20, 2007 09:08 AM
drSquish
12
Dec 5, 2005 07:25 PM
Groove_D
May 1, 2004 12:46 AM
