2000 EX, GSR Swapped, Car Bogging/Speedo Spazzing
Old Oct 17, 2010 | 07:37 PM
bmxkills's Avatar
Default 2000 EX, GSR Swapped, Car Bogging/Speedo Spazzing
Alright guys, I know it's going to end up being something stupid, but I can't figure this out haha. The car's a 2000 EX, with an OBD2 GSR block/tranny, B16 head, everythings legit (poor man's type r). The car ran perfect, until last night. The car bogs terribly at 5,000rpmish when floored, and the speedometer spazzes out. Taking the foot off the gas, there is no problem with the speedo, and corrects itself. Driving normal, the car is fine, but when floored, it just falls on its face at 5,000. I replaced the rotor and coilpack, I'm getting a cap tomorrow, and that's the only thing I found wrong with the car. I can see the rotor and coilpack affecting this, and even the cap, but the cap really doesn't look bad, just has a small crack. I can't see this causing this much, I'm thinking dizzy guts? Anyone?
Also, my car seems like it's running rich now... Dizzy, or sensors it seems like?
Last edited by bmxkills; Oct 18, 2010 at 09:46 PM. Reason: new update, read ending.
Old Oct 18, 2010 | 09:36 AM
bmxkills's Avatar
Default Re: 2000 EX, GSR Swapped, Car Bogging/Speedo Spazzing
BUmp
Old Oct 18, 2010 | 09:45 AM
Former User's Avatar
I like your expression "speedo spazzing".
Have you checked whether 7.5A dash fuse 15 is blown?
Old Oct 18, 2010 | 10:51 AM
bmxkills's Avatar
It's fine
Old Oct 18, 2010 | 11:23 AM
Originally Posted by bmxkills
It's fine
Did you test installed fuse 15 with a test light?
Have you checked the terminals in the VSS connector?
Old Oct 18, 2010 | 11:25 AM
bmxkills's Avatar
I tried another 7.5a fuse too, nothing. I don't see why this will make my car bog though.
Old Oct 18, 2010 | 11:27 AM
EJ8_Man's Avatar
I had the same problem last night actually. I have a water leak on the passenger side, which shorted out the "C" connector on the ECU. My speedometer spazzed out, my car fell on its face as I tried to accelerate, and I threw a check engine light. The next day, the connector dried out, and my car came back to life. It might be worth a look. I'm assuming your car is OBD2B, I have a 1999 Coupe B18C ITR swap.
Old Oct 18, 2010 | 11:28 AM
It's the fuse that protects the circuit for the voltage regulator in the alternator.
Old Oct 18, 2010 | 12:07 PM
bmxkills's Avatar
I'll take a look, yeah, I can't find any bad fuses.
Old Oct 18, 2010 | 12:17 PM
Targa250R's Avatar
be professional
Sounds like VTEC is not engaging. Have you checked the harness connector for the VSS in the transmission? Is the Check Engine light on?
Old Oct 18, 2010 | 12:22 PM
bmxkills's Avatar
No check engine, the VSS seems to be fine, I thought the same thing, which would explain the speedo too, but idk. If I downshift from 4th to third, it runs fine, like catching it in VTEC, but it won't cross on it's own if floored.
Old Oct 18, 2010 | 03:33 PM
Jimster480's Avatar
It could be a issue with your ICM, but its weird that you can get it to run if you downshift. it really doesnt make much sense. usually things either act up or they dont.
Old Oct 18, 2010 | 05:03 PM
bmxkills's Avatar
Yeah that's why I was thinking the ignitor or something like that. Like, if I'm at let's say 4k in 4th gear, I can downshift into VTEC in 3rd, and rip 3rd, 4th, and 5th just fine, but 1, 2, and 3 at first are useless.
Old Oct 18, 2010 | 07:24 PM
Jimster480's Avatar
thats pretty weird. Like I said before, stuff usually works or it doesnt.
Old Oct 18, 2010 | 09:31 PM
bmxkills's Avatar
Just cleaned my grounds, wasn't the best contact because of the bay being sprayed for a tuck, checked my wires again, everything looks fine, and it still does it. I looked at the VSS plug, and it looks a bit dirtyish, but can't really tell because of it being dark out? But like I said, I can't see the VSS making the car fall on its face.
Old Oct 18, 2010 | 09:47 PM
bmxkills's Avatar
The car now seems to be running rich.
Old Oct 19, 2010 | 04:20 AM
Jimster480's Avatar
if the VSS doesnt report a speed then you wont hit VTEC. It would make sense that it is running rich i guess. Do you have a stock ECU in there? You should check your vacuum lines, especially to the FPR and see if they are broken.
Old Oct 19, 2010 | 06:56 AM
bmxkills's Avatar
Alright I'm gunna check the vac lines now, see what's up.
Old Oct 19, 2010 | 08:28 AM
bmxkills's Avatar
I just checked againfor any codes being thrown, it's throwing a 21, VTEC. Any idea? I unplugged the VTEC solenoid, and it still boggs at 5k though.
Old Oct 19, 2010 | 08:32 AM
bmxkills's Avatar
I'm thinking, the igniter? Because it would mess up the speedo, and cause it to bog, and if it doesn't read you're moving, VTEC won't cross. Correct?
Old Oct 19, 2010 | 08:50 AM
No, it could only mess up the tach.
Old Oct 19, 2010 | 10:22 AM
bmxkills's Avatar
The VSS seems fine, pulled it out, cleaned off contacts and everything, still does the same thing. I'm not about to just buy a new VSS for $100+ dollars when it's not the problem...
Old Oct 19, 2010 | 11:18 AM
EJ8_Man's Avatar
Do you have any friends with a ECU you can barrow? Might be worth it swapping out, and checking if it's the ECU
Old Oct 19, 2010 | 11:57 AM
bmxkills's Avatar
Eh, yeah I can try to borrow a ECU to check it, I'm still leaning towards the dizzy... It seems to be leaning out when I press the guess, or at least at idle. It idles like 45psi, and as a put on the gas, it reaches about 33ish psi at about 5k... Hmmm. But it smells like it's running rich?
Old Oct 20, 2010 | 09:17 AM
bmxkills's Avatar
Anyone?
