98 ej8/ls swap: What should be my average gas mileage?
ok guys imjust wondering i have a 98 ej8 with an ls swap, and im getting around 275 miles to a full gas of tank, is this normal?
or should i be getting more?
motor is stock only has a short ram, header and full exhaust also running an obd1 ls ecu
any input will be greatly appreciate it
To calculate your average mpg, reset you trip meter and next time you fill up the tank to full, take the number of miles on the trip meter and divide by the gallons of gas it took to fill up.
Repeat this method anytime to get your avg. mpg.
The 1998 Civic gas tank capacity should be 11.9 U.S. gallons; however, you can't really tell the actual average mpg without using the trip meter and the number of gallons needed to fill the tank, since the gas remaining in the tank may vary when you fill up unless you ran it dry every time.
The 1998 Civic's average mpg is posted at this site.
http://www.fueleconomy.gov/feg/noframes/14091.shtml
However, YMMV (Your Mileage May Vary) depending on whether the car is automatic or manual, driving habits, etc.
For example, you traveled 275 miles, filled the tank all the way, and it stopped at 10 gallons, your avg. mpg would be 27.5 which would be close to the Civic's published avg. mpg at the above site for city driving. If this was principally Hwy driving, then your avg. mpg would be low in comparison.
ok i get all that and i know im averaging about 27 mpg
but what i was trying to see is what is other ppl with the same set up that i have or similar to it they are averaging
Mention your driving style (speed racer vs grandma) as well as how much of your mileage is city versus highway driving. Without such details, gas mileage comparisons are meaningless.
is mainly regular driving and city driving and yes it includes lights and stop signs and i drive 30 miles a day
and no i dont drive like a grandma and im not a speed racer either
i race but i racemy crx at the track
oh is not about the saving of gas it was just a simple question, since in my dually i average around 23 mpg and thats with some things done to it like edge programmer andother stuff i know i can do 28 but im still working on the truck, on the one i just to have i was doing 29 but highway miles
he's not asking what his ej8 is getting. he's asking what an ls SHOULD be getting
http://www.fueleconomy.gov/feg/noframes/10677.shtml
that link could help as far as an ls motor should be getting, but you'd have to bend your numbers depending on the weight of the teg vs your civic and size of the gas tank
low430
Oct 2, 2005 01:53 PM
