how do u install a tie rod?
Old Oct 16, 2010 | 05:09 PM
dc2LS's Avatar
Default how do u install a tie rod?
well im having trouble tightening the nut on to the tie rod.It turns and turns but it wont tighten its happening on both sides.I used a C clamp to remove them because they are under alot of pressure illtry to post pics later.
Old Oct 16, 2010 | 05:23 PM
1998GsRIntegra's Avatar
Default Re: how do u install a tie rod?
You are aware you should have counted how many turns on each side before the tie rod came completely off correct? If you didnt you now need to get your car aligned. Then when re-installing just turn the tie rod on the ammount of times that you previously noted. Then set it in the spindle, put the castle nut on hand tight, then procede to tighten the nut on the tie rod with a wrench. Then run the castle nut for the tie rod all the way on and insert a cotter pin. Same procedure for both sides. Wash Rinse and Repeat. Good luck.
Old Oct 16, 2010 | 05:33 PM
94VTEC2TONE's Avatar
i think your talking about the outter tie rod or it would seem so. and even coutning threads isnt perfectly accurate you may still be off just the way it is man. but guy aboves pretty correct
Old Oct 16, 2010 | 05:53 PM
Integra4lyfe069's Avatar
so in other words that tie rod end bolt doesnt tighten until the balljoint is in place?
i need to do tie rod ends myself n never did them b4. this was helpfull.
Old Oct 16, 2010 | 06:49 PM
dc2LS's Avatar
I didnt take off the whole tie rod sorry for not explaining correctly .I just cant get the outer tie rod nut on i think if i loosen the whole tie rod i might just get it right in.Ill try it tomorrow
kevinmcc2
Mar 25, 2013 10:26 PM
skipbudlong
31
May 6, 2010 10:21 AM
yoffer
Apr 29, 2007 08:33 PM
msinsky14
50
Apr 21, 2007 03:50 AM
Groove_D
Nov 13, 2005 11:36 AM
