K20a2 vs a3
Old Oct 16, 2010 | 02:53 PM
jksmith's Avatar
Default K20a2 vs a3
my knowledge of K Series is very very little
planning on building the motor (pistons/rods), so is there any other differences bottom end wise?
Also whats the difference in the Heads? Ill be going aftmkt valve train and cams
Old Oct 16, 2010 | 03:40 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: K20a2 vs a3
Nearly everything about the A3 motor is less than ideal when compared to the A2 motor and it's a huge reason why most people only mod the A2 motors. Weaker rods, lower compression pistons, a head that flows less and a VTEC system that only worked on the intake side are just a few of the examples. For reference, the RSX came with two motors, the 160hp A3 and the 200hp A2, so you can see which one was the better starting point. IMO the A3 was like the D series to the B series engines.
Old Oct 17, 2010 | 07:54 AM
Type-ARR's Avatar
Go to k20A.org and join, they have all the help you need. Also get the Type-S A2, like my friend above stated the A3 has "fake" Vtec and is just an allround weaker starting point compared to the A2.
clicky79
May 8, 2019 09:23 PM
sfwdcrx
Apr 8, 2008 06:36 PM
ham
Apr 11, 2007 08:26 AM
t0pnotch1
Jul 19, 2006 10:29 PM
