OBD2 to OBD1 auto need options
Old Oct 16, 2010 | 07:52 AM
Lmgrcivic's Avatar
Default OBD2 to OBD1 auto need options
I have a OBD2 car thats a auto but want to switch to OBD1 what can I use or can I have a another ecu chipped for it to work
Old Oct 16, 2010 | 10:14 AM
94EG8's Avatar
Seagull Management
Default Re: OBD2 to OBD1 auto need options
Can't be done, not without swapping the tranny, intake manifold and throttlebody and adding in a manual kickdown cable anyway. This assuming its for a D-series B-series is a little different.
Old Oct 16, 2010 | 10:44 AM
Manny 77's Avatar
IS your car vtec or not??? Use a p06 if si not or a p28 if is vtec and the obd2 to obd1conversion harness from ebay for 40 bucks and you r done...
Old Oct 16, 2010 | 10:59 AM
94EG8's Avatar
Seagull Management
Doesn't work that way for an automatic. OBD1 D-series tranny has 2 lockup solenoids, and a manual kickdown cable thats it. OBD2 D-series tranny has 2 lockup solenoids, 2 shift solenoids, 1 linear solenoid, mainshaft speed sensor and a countershaft speed sensor. The OBD1 ECU just doesn't have the circuitry to control the extra solenoids and sensors on the OBD2 tranny.
Old Oct 16, 2010 | 11:15 AM
Lmgrcivic's Avatar
Aight thanks guys for the help
Old Oct 16, 2010 | 12:57 PM
94EG8's Avatar
Seagull Management
No problem, unless you have some physical disability that prevents you from running a 5 speed theres really no reason not to. Honda automatics are geared pretty craptasticly and aren't know for being overly tough.
Lmgrcivic's Avatar
anyone know a way that I can get rid of the evap **** now without throwing the check engine light
Old Oct 16, 2010 | 12:58 PM
Lmgrcivic's Avatar
oh and the reason its a auto its my girls car
Old Oct 16, 2010 | 01:03 PM
94EG8's Avatar
Seagull Management
No, its got to be there, JDM ECU may not look for it, but JDM automatics are different (more like an OBD1 tranny) so again you can't use the ECU.
Teach her to drive stick? Most of the girls I know drive stick, i'm not sure where people got the idea that girls couldn't.
screen_name
May 14, 2009 05:25 PM
SOHC_MShue
Jun 13, 2007 07:39 AM
ronald55555
Oct 23, 2006 07:55 PM
zacknj
Oct 13, 2005 05:43 PM
bearboy80
Sep 4, 2004 03:14 PM
