B16a2 Block with B16B crank?
Old Oct 16, 2010 | 12:30 AM
93xsi's Avatar
Default B16a2 Block with B16B crank?
i would like to use a b16a2 block with a b16b crank and ls rods not sure on pistions. ify i have access these parts and trying to put some thing together..... so would this bolt up?
Old Oct 16, 2010 | 04:50 PM
PyroProblem's Avatar
Default Re: B16a2 Block with B16B crank?
No. Generally speaking, you have to match the rods to the crank.
LS rods -LS crank
B16B rods- B16B crank
Old Oct 16, 2010 | 10:48 PM
anothersickhatch's Avatar
a b16b crank is essentially the same as an integra type-r crank or a gsr crank. it is balanced and lightened, but the b16b motor is basically a de-stroked 1.8 liter as far as i know. the rods and pistons are very unique.
Old Oct 17, 2010 | 08:43 PM
jdmboyef9's Avatar
This will not work, B16B crank will only work in a 1.8/2.0 block. The B16B block is the same deck height as a B18C....Actually the B16B and B18C blocks are the same exact block. B16B and B16A blocks are different deck height therefore the crank will not swap.
You can put it in an LS or b20 so long as you have the matching rods/crank.
My old B20 had an ITR crank/rod setup in case someone wants to say it won't work.
Now you know, and knowing is half the battle
Old Oct 17, 2010 | 08:47 PM
jdmboyef9's Avatar
FYI, B16B crank is not the same as a GSR or ITR. Different rod/stroke, only the same block. In case you do make the mistake of swapping a B16B crank into a B16A block, the pistons will extend out of the cylinders and hit the head....it won't even turn over
Old Oct 17, 2010 | 08:59 PM
projectTeG's Avatar
to correct yal, the b16b crank has the same exact stroke as the b16a crank(77.4mm)
theoretically it would work with the b16a length rods in the b16a block, but you have to account for the fact the the b16b came with the newer thinner "big end" design of the gsr/itr rods so the fatter b16a rods will not bolt up to the ctr crank.
now if you get a custom rod then problem solved, but not worth the time IMO
Old Oct 18, 2010 | 09:42 AM
93xsi's Avatar
Thanks for the info
Pinguim
32
Feb 12, 2010 02:12 PM
rdssk8rcs1
Oct 13, 2008 04:52 PM
Kelly.
42
Oct 18, 2005 11:14 PM
pane93civhb
Oct 16, 2005 08:18 AM
turbotypeR@SPEC
Dec 5, 2004 10:51 AM
