EM1 with gsr smoking problem
Old Oct 13, 2010 | 06:45 PM
jorge_131's Avatar
Default EM1 with gsr smoking problem
Ok This is my problem. i bought a used gsr shortblock from someone and put a built pr3 head on it (which was working perfectly fine before i removed it from another engine). i finish swapping everything over and i start the car and smokes like crazy. The smoke is white and dense, and it also smells sweet. I did remove each individual spark plug to see if i could trace which cylinders were causing the smoke, and it was 1, and 4.
Could it be just a blown headgasket caused by a warped head or could it be something else? Im kinda stumped at this point.
Old Oct 13, 2010 | 07:26 PM
savageemode's Avatar
Default Re: EM1 with gsr smoking problem
can be the headgasket
Old Oct 13, 2010 | 09:09 PM
KRV's Avatar
KRV
drain some of your oil, if it looks like chocolate milk then its probably your head gasket.
Old Oct 14, 2010 | 01:59 AM
THE COMEBACK's Avatar
maybe you have too much oil. that would make it smoke like a train. and u should always get a new head decked to insure that it will work properly.
Old Oct 14, 2010 | 10:20 AM
blown_ss's Avatar
if it smells sweet i would put money on that head gasket. antifreeze smells sweet when it burns.
01_civic
Classic Hondas
Jun 3, 2012 06:58 PM
Hiboost 2.0
Aug 12, 2011 03:37 PM
2001tegy
Sep 12, 2009 01:00 PM
thebleek
Oct 9, 2008 04:42 AM
EF9 CiviC SiR
12
Jul 9, 2004 09:56 AM
