Should I roll fenders?
Im on stock springs right now, but if I ever go lower I'll change spring for the Tein dress up crap, which drops an inch.
Thx for you feedback!
Good didnt wanted to get rid of the inner fender trim. Montreal is one nasty city, rather keep the body of the car as protected as possible.
i mean maybe after the spring but i doubt it. but if u do just use double sided tape to hod the fenderliners on. i am a big fan of them i hate with **** gets all dirty from not runin them unless the ca is like a weekend warrior or sees the road several times a year
if it rubs throw some camber at it should tuck in the fenders.my old set up was 18x9.5 +50 in the rear.altho my tire size was bigger it would rub like crazy on dips an bumps.tire size was 245/40
Thx for the offer, I'll check once installed and I'll post some pictures.
Cool Cool Island Breezes. BOY-EE
Adjustable upper mounts don't work with S2000s. The shock body doesn't control the wheel's position since it's a double wishbone car. It has stock adjustment cams for camber. You turn them one way for negative and the other way for positive.
It has adjustments for camber and toe front and rear. It also has a caster adjustment up front. It's like a gumby doll. The adjustment range is pretty big also (for stock parts).
If you need to go outside of that adjustment range, it gets expensive. You go with adjustable ball joints.
According to the Wheel fitment guide :
Front :
7.5? to 8.5? wide wheel: 235 tires: +58 offset minimum
I have a 225 but with 50 offset, so 10mm less in tire but 8mm more in offset, should clear??
Rear :
8.0? to 9.5? wide wheel: 255 tires: +50 offset minimum
Exactly my size!
hey ive got an ap1 with rolled fenders i sold my rims but the rear was 18x10 and front was 18x8.5 and lowered on eibach springs about 1 inch i would only rub on like giant dips at a cruising speed like 65 to 70 tire specs 225/40r18 and 255/40r18 and fenders are rolled hope i helped
climb_on
20
Mar 14, 2008 09:12 AM
