Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
18x8 +46 with 225/45/18
Old 05-03-2011, 12:41 PM
ilovejdm's Avatar
Default 18x8 +46 with 225/45/18
Will I have any problems with rubbing with this setup? Will it look ok? I'm giong to lower on eibach sportlines or tein s-techs. 2007 Accord Sedan.
Privat Akzent are the wheels I want to order.
Old 05-03-2011, 03:23 PM
My Name is Nobody
MSchu's Avatar
Default Re: 18x8 +46 with 225/45/18
I'd say you are okay depending on how low you go. +46 is not that bad.
Old 05-03-2011, 03:45 PM
ilovejdm's Avatar
how do you think they will sent in the fender well? I just don't want them to stick out in the front.
Old 05-03-2011, 06:21 PM
My Name is Nobody
MSchu's Avatar
use this calculator to figure out differences in rim to fender layout as well as inner well clearance.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old 05-03-2011, 06:55 PM
ilovejdm's Avatar
Thanks man, according to that calculator those wheels will be 10 mm inwards and 28 mm outward.
about 1.4 inches wider than my stock 16x6.5 inch wheels.
Should sit pretty nicely???
Old 05-03-2011, 07:01 PM
!inspire1318!'s Avatar
they will fit fine..I have 18x9 in the front and mine sit flush. You should go 225/45/18 if you consider lowering your car more
Old 05-03-2011, 07:04 PM
ilovejdm's Avatar
225's are what I plan on running just to be on the safe side.
What offset are you running? have any pics of your car?
Old 05-03-2011, 08:39 PM
franklinhid's Avatar
+46 is toooo high of an offset. it will look too sunk in. 18x8 with something in the +30's offset will make it look oem. something in the +20's with make it alittle more flush.
225/45/18 should be fine. i would personally run a 225/40/18
i had a 07 accord n was a huge ***** n tried all types of setups
i currently have an 08 tsx and 05 accord wagon and im a huge wheel ***** n have also tried out all types of wheels. deff had my share of 17/18/19/20 inch rims in all different widths and offsets
Old 05-03-2011, 10:38 PM
ilovejdm's Avatar
+30's offset make it look oem?? It has 6.5 inch wide wheels with a +55 offset stock. I already did the calculator and it says it'll be 28 mm further out than the stock wheels
Old 05-04-2011, 07:10 AM
My Name is Nobody
MSchu's Avatar
exactly... you got it. 8" is going to be good.
if you want a real trick set up... run 9-9.5 f and 8 r
Old 05-04-2011, 12:57 PM
Grohe's Avatar
http://www.v6performance.net/forums/...er-set-up.html
18 x 8 +40 mm offset
225/45/18
Old 05-04-2011, 02:05 PM
yea that set up is perfect although I would do 225/40/18. but it depends on how low your car is. +46 is pretty moderate which is fine. Mine is 18x9 +37 and its flush. I rub a little bit but my car is also dropped as low as it can go on tein ss.
sydistik
09-14-2010 05:51 PM
anphan05
12-19-2008 09:18 AM
jdmhondaboi626
11-21-2007 09:53 PM
HS2G
06-16-2007 11:50 PM
MikeD
07-24-2001 09:05 AM
Quick Reply: 18x8 +46 with 225/45/18
