A D16ZC SWAP GONE WRONG - no spark or fuel
I need help finding why i can't get spark or fuel. From the motor i swap! the motor is a D16zc off of a 95 civic Ex v-tec.
Its in a 97 EK9 civic hatch now. I got every things for the swap i need. But it still wont run. I Got a OBD2 to OBD1 ECU JUMPER HARNESS also OBD2 to OBD1 distributor jumper harness.
Other then that every thing bolt up and plug up! I got a 95 civic ECU that came with the motor. I check all the grounds! but all of them are good.
just dont know where to go from now! lol it kick my A** .
ThankYou
Souphane87
ThankYou
Souphane87
ThankYou
Souphane87
ThankYou
Souphane87
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Check hood fuse 44 and dash fuse 13.
Clean and tighten the ground wire attached to the thermostat housing.
Thanks Bro Ill check out the fuses. The wire i didnt touch, its all factory still. The only thing that different is just those two jumper harness. im all new in this honda tuneing. So I need all the info i can get make this car running. Thanks for all your hlep. ill keep you guys update.
Souphane87
Souphane87
i cleaned out and checked the grounds. i checked all the fuses and checked to make sure all plugs are plugged in. still no luck! still no spark or fuel!!
scbmx87
Oct 26, 2008 06:49 PM
donvito#1
May 2, 2008 08:24 PM
