d16z6 turbo idle issue
Old Oct 12, 2010 | 04:51 AM
joshrww's Avatar
Default d16z6 turbo idle issue
ok so i am having a problem with my idle on my turbo d16z6 it is mildly built with a skunk2 pro intake and 750cc injectors walbro 255 hondata ecu (s200) getting s300 soon. my problem is my idle stays at 1500 - 1400 at all times and if i hit the gas and let off real fast it slowly drops back to 1500 no check engine lights are on and iv replaced everything you could think of from the IACV to the FITV and nothing has fixed it... no vacuum leaks anywhere.
note this.. i do have a aftermarket radiator and fan system and my fan always stays on.. keeping my engine cold my temp gauge always reads below cold.
not sure if that would have anything to do with it just letting you guys know..
any help would be helpful
Old Oct 12, 2010 | 07:36 AM
mtber's Avatar
Default Re: d16z6 turbo idle issue
The issue could be anything from your iacv duty being turned up in your s200 tune to your ignition timing at idle load columns being a bit too advanced or erratic etc.
Have your hondata tuner inspect the car.
Old Oct 14, 2010 | 02:38 AM
joshrww's Avatar
thanks i took it to the shop down here and the guy changed the duty of my iacv but that didint fix it.. any other thoughts? im really starting to think its got somthing to do with my map sensor or my cooling system.
Old Oct 15, 2010 | 07:59 AM
rndmheroxx's Avatar
i would make surrrreeee you dont have a vacuum leak, that what it sounds like it is to me. cant say much else without looking at datalogs
The Destroyer
Sep 15, 2008 09:08 PM
c0nspire
Mar 10, 2006 02:41 AM
martingouda
Nov 24, 2005 11:54 AM
Firefoxracer
Jun 16, 2005 08:04 AM
Efil4zaggiN
Dec 17, 2004 07:32 PM
