jdm h22 hesitation problems
i swapped my h22a4 with a jdm h22a with a p13 ecu . and it was running good until the other day. i noticed a lot of hesitation when peaking around 4000 rpms. i just got a new distributor, ngk wires and ive had ngk iridiums on there for awhile . none are fauled and they all have spark so its not missing. can anyone help me please??!!
i bought some Iridiums... turned out to be junk. somehow they fowled out. may have spark but how strong? might wanna try getting some cheap-o- copper ones and try it again..... the simple things always bite you in the ***
Oxygen sensor will not lead to hesitation at WOT; if not working right you may bog/hesitate in low rpm's at something like 0-20% throttle.
I had this same issue recently, i think my issues was injectors, because after running seafoam through the fuel system it cleared out the issue. Though my car still runs incredibly rich.
I agree, You need to run 92+ octane fuel. but I replaced my Dizzy, Knock Sensor, AND cleaned the EGR system, (YES IT HAS ONE, DRRR) and I still have the hesitation.. It's got to be a lean spot with a misfire.
Nothing a good shop with a DSO cant find. My old H22 Accord had a hesitation that turned out to be a faulty coil.
I assumed my engine was running really rich because of smoke and black soot but after getting it on a dyno I found it was running extremely lean (13.7:1 below 4.5k and 14-14.3:1 above 4.8K). Result, good torque figure, crap hp figure, heaps of smoke out back and a black bumper. Wasn't running rich at all, just dangerously lean with my knock sensor working over time and my ignition timing being permanently retarded!
I have found that hesitation means one thing, ignition cut. You need an air fuel ratio to know if its a lean spot. A misfire will trip a CEL, knock is corrected for on the fly.
Quick question, how do you know its running rich? Smoke behind you when you floor it? Black soot on your rear bumper?
lak8
Oct 6, 2005 05:03 PM
lol but mines newer, I'm sure I'll run into this somewhere down the road. Lol
